Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Sep 2014
    Joel
    Colorado
    Default Installing procharger
    Hi everyone I have a question has anyone installed a procharger on an 96 Fbody without using the FMU from procharger. I purchased a kit that was supposed to be complet and after receiving the kit the FMU is missing.
    What do I need to install to take place of the fmu. I have a fuel pressure regulator for boost reference from Aeromotive., I now I need larger injectors just not sure what size yet, daul fuel pumps, and a tune.
    Ur gonna need a boost ref fpr... larger injectors... (i run 60 lbs) and fuel pump upgrade depending on how much boost and power, maybe a dual pump set up.
    OWNER/ADMIN
  3. The Following User Says Thank You to popo8 For This Post:
  4. #3
    You do not need a Boost ref fpr. Stock will raise pressure 1:1 with boost. I strongly recommend the lonnies double pumper pump setup and deka 60lb injectors
  5. The Following User Says Thank You to SSlowBoat For This Post:
  6. #4
    Do the boost ref fpr...
    OWNER/ADMIN
  7. The Following User Says Thank You to popo8 For This Post:
  8. #5
    LTX Regular
    Jul 2013
    Ernie
    97 Mullet
    Minot
    If you plan on doing the work yourself and want to save some money. Check out a DIY for twin pumps. http://ls1tech.com/forums/fueling-in...ick-cheap.html
    Popo let me know if I'm stepping on anyone's toes by posting that link.
    355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
    www.fquick.com/SleepyZ
    <font color=#ff0000>
  9. The Following User Says Thank You to sleepy_z For This Post:
  10. #6
    They did you a favor but not including the FMU, I highly suggest a Boost Reference regulator as Po says.
  11. The Following 2 Users Say Thank You to MoeHorsePower For This Post:
  12. #7
    Quote Originally Posted by sleepy_z View Post
    If its not a specific company push. No issues. I got banned over there a while ago...
    OWNER/ADMIN
  13. The Following User Says Thank You to popo8 For This Post:
  14. #8
    Quote Originally Posted by MoeHorsePower View Post
    Moe is the reason my procharged camaro has one...
    OWNER/ADMIN
  15. The Following User Says Thank You to popo8 For This Post:
  16. #9
    Sep 2014
    Joel
    Colorado
    I have the boost reference reg. I also have a set of dual fuel pump 255 I picked up from Fastbird awhile back. I would like to run some were in the Naborhood of 14# of boost.
  17. #10
    What headunit are u gonna use?
    OWNER/ADMIN
  18. The Following User Says Thank You to popo8 For This Post:
