Results 1 to 10 of 11
08-23-2016, 11:38 AM #1Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Have questions on what size injection to run
I'm looking to see what size injections every on is running with a procharger running 14#or more. I live in high altitude 6,500 ft. Built motor Lt-4 intake Afr 227. HR spec by Loyd.
08-24-2016, 03:25 PM #2VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Here's a link to a calculator that should help.
http://fuelinjectorclinic.com/flow-calculator
Good info here also
http://www.onallcylinders.com/2012/0...injector-size/
Sent from my iPad using TapatalkLast edited by 1QUICKZ28; 08-24-2016 at 03:40 PM.
08-25-2016, 06:31 AM #3
What is your fuel system capable of, what PCM are you running, and do you plan on using meth to supplement fuel up top?
08-25-2016, 06:51 PM #4Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
Dual welbro 255 stock rails aramotive FPR. Stock pcm, did not plan on meth injection to supplement. But I could be wrong this my first supercharged build.
Sent from my SM-N915V using TapatalkLast edited by Camaro96; 08-26-2016 at 11:38 PM.
08-26-2016, 09:14 AM #5
In that case, I would run some ID1000s if you want to be super safe, and or push it later on. But, since this is the real world and spending $800 on sticks is crazy for most... grab some 80# deka sticks. Just be aware you will be limited by fuel and not air IMO.
08-26-2016, 09:47 AM #6LTx Guru
Keep an eye on the Aeromotive AFPR if it's the LT-1 specific unit. I've seen a few of those fail over the years. Bumping the Deka's to 4 bar (58psi) will gain you 15% more headroom.
08-26-2016, 09:56 AM #7
08-26-2016, 10:04 AM #8LTx Guru
True. The high pressure version of the Walbro makes sense for FI.
08-26-2016, 12:57 PM #9Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
Is it an issue with the pumps themselves or the pumps paired with our stock fuel lines?
08-26-2016, 01:25 PM #10
