Results 1 to 9 of 9
08-17-2016, 07:14 PM #1InActive Member
- Oct 2012
- 92 camaro rs ,93 camaro z28
- delaware laurel
- 415
looking for c5 info (brake swap )
looking for a simple question ..to be answered i was told that ls1 spindles would fit c5 calipers and rotors ? ....i cant seam this to be true...
also whats the best adapter bracket?
08-17-2016, 07:22 PM #2Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
From what I have read is that you can find hardware, brackets. To convert to the C5 rotor and brake setup.
08-17-2016, 07:53 PM #3LTX Master
- Nov 2008
- Enrique
- 93 Z28
- Houston/Clear Lake
- 615
Camaro96, how did you get that spindle cut so well? It looks perfect.
08-17-2016, 11:15 PM #4Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
I wish that's just pics I had after doing research and it's on the mod list .
08-18-2016, 10:38 AM #5Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
Nope. For C5 brakes you have to cut the ear and use a bracket. HOWEVER..........I am pretty sure that the LS1 spindle will fit the Gen 1 CTSV Brembo caliper without issue and use a C6Z rotor. BUT, you will need to have the proper wheel offset to clear the caliper. http://ls1tech.com/forums/suspension...ll-w-pics.html
08-18-2016, 06:06 PM #6Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
Red lines are where you gotta cut. Stock lt1 spindles
14.307@98.21, 2.155 60'
The Following User Says Thank You to Dan For This Post:
08-18-2016, 06:51 PM #7Long Live the Opti
- Sean
- Fort Wayne, IN
- 12,072
08-18-2016, 07:27 PM #8"The Hammer"
- Nov 2009
- JimmyMo
- 1994 Trans Am
- 2,531
You are correct. The LS1 spindle will take a ctsv brembo caliper. you're going to want a minimum of like an 18" wheel to clear with some clearancing of caliper, 19" wheel to be really comfortable. I have a set of 18" rims for my trans am and I had to grind down a couple of humps on the calipers to get them to clear."Only in the Corps can you put three guys in a room with an anvil and a rubber mallet, come back 15 min later, and the anvil is broken, the rubber mallet is missing, and nobody saw a damned thing!"
08-19-2016, 02:04 AM #9Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
