Results 1 to 5 of 5
    Oct 2013
    Evansville, IN
    Default Header Gasket - Use Or Not Use
    Have my hot side mocked up and ready to make final assembly.... How many turbo guys not running header gaskets?? Seems the people I know who are running turbos are spilt 50/50.... I'm told not running gaskets will reduce the chance of gasket blow out.
    What's your thoughts??
    Thanks!! - Tim
    96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
    I run copper RTV on aluminum MLS dead soft gaskets, so far no blowouts. My setup is prob on the high side of backpressure as well.
    Oct 2013
    Evansville, IN
    Great to know shownomercy... Do you know what part number?? I have AFR 210's
    I used these
    https://www.summitracing.com/parts/php-66031
    But I have stock D port heads, not sure they will work on AFRs.
    Sep 2015
    BUZZ LEACH
    1997 trans am
    Percy's High Performance XX Carbon exhaust header gaskets are the best.
