Results 1 to 9 of 9
Thread: Nitrous/fuel system/high octane
08-01-2016, 11:23 AM #1
What is the most nitrous that can be run on a stock fuel system with an upgraded 255lph pump?
Also when would it be the best time to run higher octane/race fuels (what shot)?
Thanks
08-02-2016, 05:47 PM #2The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
i was running a 200 shot and over fueled my car and lifted a ring land
08-02-2016, 09:27 PM #3
My bottom end consists of forged pistons and rods , aftermarket crank if that helps
08-02-2016, 10:01 PM #4The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
what is your ring gaps?
08-03-2016, 09:45 AM #5
Not entirely sure. The guy built my motor knew I was running nitrous. I needed a motor quick tho. Next motor I'm going to be involved in more
08-03-2016, 06:41 PM #6The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
ring gaps can really limit how much nitrous you spray ... but if they are gapped for a NA motor ... dont go past a 150 shot ...
10-13-2016, 09:51 AM #7
10-14-2016, 06:05 PM #8
255 pump on otherwise stock fuel system is good for a bit over 500whp....how much you can spray is dependent on what you make on motor
11-09-2016, 10:34 AM #9
