Results 1 to 10 of 16
07-20-2016, 10:20 PM #1
What numbers are you guys producing
What numbers are you guys producing with Gm847 and ported heads. Also what kind of track times do you guys get out of it.
I currently have
Gm847
Ported heads larger valves and matched intake,
52mm stock ported to
355 forged bottom end
4l80e
Dana 60
Supporting moda
I understand with the 4l80e my numbers might be lower than many but just shoot away
07-20-2016, 10:44 PM #2The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 1994 Firebird Formula
- moore, ok (south okc)
- 3,274
http://ltxtech.com/forums/showthread...ars-on-LTxTech <----- dyno list
http://ltxtech.com/forums/showthread...-LTX-cars-list <---- cam only list
http://ltxtech.com/forums/showthread...get-it-started! < ------ fastest LTx cars94 Formula "budget build" #thebeaterbird
07-21-2016, 05:28 PM #3
Thank . So I'm assuming my forged 355 stock compression 52mm ported tb/intake
With all supporting mods gm847 porrated heads with larger valves( similar to le2) 3k stall 4l80e Dana 60
My dyno 349hp pull to 6500 and 298tq
And 8.7 1/8 at 84 is pretty low for this settup?
This was street tuned b4 my solomon tune. I haven't run again since I think I have other issues
07-21-2016, 06:02 PM #4The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
What is the weight of the car. What size gear and what size stall?
07-21-2016, 06:57 PM #5The Nitrous Outlet Junkie
- Apr 2010
- Troy
- 3,274
your hp looks good ... but TQ numbers seem VERY low ... my 95 with 148K miles and 100% stock (even a paper air filter) made 245hp and 275tq ...
with you having
"355 stock compression 52mm ported tb/intake With all supporting mods gm847 porrated heads with larger valves( similar to le2) 3k stall 4l80e Dana 60"
you should be making well over 350tq94 Formula "budget build" #thebeaterbird
07-21-2016, 09:37 PM #6
I made 260/285 with just a catback, tho that dyno makes high numbers
03-06-2017, 09:18 PM #7InActive Member
- Mar 2017
- Mike Edwards
- 1997 Camaro SS
- North Hollywood, CA.
- 5
97 SS, 383, TFS, Comp 268HR, headers, CAI. 336whp, 375wtq.
03-06-2017, 10:57 PM #8"The Rock"
03-06-2017, 11:40 PM #9
The Following User Says Thank You to anniversaryss For This Post:
03-07-2017, 08:25 AM #10Xtreme Member
- 7,269
