Results 1 to 10 of 10
    Sep 2014
    Joel
    Colorado
    Default Possible intake leaking
    Hi fellow LTX enthusiast. I'm having a coolant leak that I can not detect were it's coming from. When I park the car I find coolant on the floor of my garage up in the front of the engine on the drivers side.
    Can the leak be possible coming from the intake?
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    Nope. No coolant goes through the intake manifold on the LT1/4 motors.
  3. The Following User Says Thank You to Fastbird For This Post:
  4. #3
    Mar 2015
    Dan Dalessandro
    1997 Camaro Z28
    Water pump most likely
    14.307@98.21, 2.155 60'
  5. #4
    Sep 2014
    Joel
    Colorado
    @Fastbird and
  6. #5
    Sep 2014
    Joel
    Colorado
    Thank you @Fastbird and @Dan for your response. It will make it easier to fight with the shop that did the opti replacement and had a coolant leak every since.
    This really sucks to by injured and not able to work on the car myself.
    Thanks again guys
    Joel
  7. #6
    Feb 2015
    1995 Z28
    Well technically you should have started off with this info "It will make it easier to fight with the shop that did the opti replacement and had a coolant leak every since."
    There are more variables to consider.
  8. #7
    LTX Regular
    Jul 2013
    Ernie
    97 Mullet
    Minot
    A coolant system pressure tester should help find the leak pretty easily.
    355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
    www.fquick.com/SleepyZ
    <font color=#ff0000>
  9. #8
    Long Live the Opti
    Sean
    Fort Wayne, IN
    Quote Originally Posted by sleepy_z View Post
    Yep. If you have a harbor freight nearby just grab one there and put the cooling system under about 15lbs of pressure. You'll find that leak quickly. Could be something as simple as a hose needing adjusted/tightened.
  10. #9
    Sep 2014
    Joel
    Colorado
    Thank you guys for all the advice. I found that the water pump gaskets are leaking again.
  11. #10
    Long Live the Opti
    Sean
    Fort Wayne, IN
    It's normally not required (I've done dry installs many many times) but a VERY THIN coating of RTV on the gaskets will help them to seal.
  12. The Following User Says Thank You to Fastbird For This Post:
