Results 1 to 5 of 5
Thread: How to remove a bent Valve.
06-29-2016, 07:22 PM #1
Has anyone cut a valve stem so you could remove the valve. I have one bent valve on a new set of AFR heads. Can't figure out how it happened. Decided to adjust rockers one last time before going for a cruise and when I got to number 7 exhaust, it had a bent valve. Only time motor ran was adjusting tune in garage. No hit on piston, no mark on the valve. I can't figure it out, but need it removed. Any trick to this?
Sent from my SM-N920V using Tapatalk97 Mystic Teal Camaro, Forged 396 Single plane EFI 24x N20, Finishline 4L60E, S60, M/T Drag Radial
06-29-2016, 08:07 PM #2LTX Master
- Nov 2008
- Enrique
- 93 Z28
- Houston/Clear Lake
- 615
I don't know, but that's a mood killer.
06-29-2016, 09:50 PM #3The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
If it's bent the guide will more than likely need replaced as well. I guess you could cut it, deburr the edges, and pull it out just to see, but I would check that guide over well
06-30-2016, 05:47 AM #4
Will check the guide when removed but looks fine. At the moment.
You are not kidding about mood killer. Would have been driving it that weekend. Firebird 1995...cut with a grinder wheel you think. If I remove rocker studs, that may work
07-06-2016, 07:23 AM #5
Cut valve with a cutoff wheel and guide looks good. I did an easy check for to much play and it passed. New valve and seal back in place. Retainer had a few marks on it from where the rocker hung up, new one should be here today.
