Results 1 to 10 of 27
Thread: Code 51 and others
06-08-2016, 05:15 PM #1InActive Member
- Jun 2009
- Brandon S.
- 1994 Trans Am
- Houston TX
- 92
Code 51 and others
Went to O'Reilly last week and got my car scanned. Came back with 8 codes:
-42
-43
-44
-45
-51
-53
-54
-55
Ive talked to a few different people so far and it seems the consensus is I need to fix code 51 before I touch anything else. The car idles rough(fluctuating between 510 and 580 at operating temp), surges audibly and visually(rpm and voltage gauge), does not accelerate over 2100-2200 rpm without some kind of shaking. Feels like all the timing is gone. Lloyd Elliott suggested that the car is in limp mode and I need to replace the computer and check out my entire harness for damage. Moe Bailey also told me to attempt to source another computer to attempt to eliminate the issues as well as check out the opti using the shbox.com check method.
If anyone else has any ideas, I would love to hear them. Im going to go ahead and attempt to find another computer local if I can. If anyone has one they would let go for cheap PM me.94 Trans Am A4 Almost Stock
06-08-2016, 05:27 PM #2InActive Member
- Jun 2009
- Brandon S.
- 1994 Trans Am
- Houston TX
- 92
06-08-2016, 09:11 PM #3LTx Guru
Was the scanner they used an Innova? If so the data base of codes stored in the scanner for the OBD-1 LT1 is corrupt, and produces a list of codes just like that. 44 and 45 contradict each other, indicating the O2 sensor is stuck at a lean reading and a rich reading. 54 is not a valid code. GaryDoug, the author of Scan9495 discovered the source of the problem, and I have seen people with the same list of incorrect codes several times. They are not real codes.
Check with O'Reilly. If it was an Innova, show them this post:
http://www.firebirdnation.com/forums...canner-review/SOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-08-2016, 09:16 PM #4LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
Yep, those are bogus. Seen them before many times. Wrong scanner was used.
06-09-2016, 09:09 AM #5Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
The codes that you are getting some deal with the o2sensors and the other have nothing to do with anything on your paticular car here is a list of the code definitions
2 Sensor Signals Swapped Bank 1 Sensor 2/ Bank 2 Sensor 2
P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
P0045 Turbo/Super Charger Boost Control Solenoid Circuit/Open
P0046 Turbo/Super Charger Boost Control Solenoid Circuit Range/Performance
P0047 Turbo/Super Charger Boost Control Solenoid Circuit Low
P0048 Turbo/Super Charger Boost Control Solenoid Circuit High
P0049 Turbo/Super Charger Turbine Overspeed
P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
P0053 HO2S Heater Resistance (Bank 1 Sensor 1)
P0054 HO2S Heater Resistance (Bank 1 Sensor 2)
P0055
06-09-2016, 02:51 PM #6LTx Guru
No. Those are not correct codes. OBD-1 does not use the P0xxx format. The best quick reference for codes is Shoebox's list, which is SPECIFICALLY for the LT1:
http://shbox.com/1/Dtcs.htmSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
06-10-2016, 10:51 PM #7InActive Member
- Jun 2009
- Brandon S.
- 1994 Trans Am
- Houston TX
- 92
Ok so I havent got the car rescanned yet. Ill be doing that tomorrow. I did get some data logs tonight with my roommate. Here they are for anyone who wants to take a look.
https://drive.google.com/open?id=0B8...jl3dkY4R2x0T2M94 Trans Am A4 Almost Stock
06-11-2016, 08:03 AM #8LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
According to the "part throttle driving" file, there are no trouble codes.
You might want to use my scan app instead, because this one wont save the log file in a universal format that anyone can view.
06-11-2016, 11:50 AM #9InActive Member
- Jun 2009
- Brandon S.
- 1994 Trans Am
- Houston TX
- 92
Will do. I'll do that this evening. Thank you for responding.
06-11-2016, 01:33 PM #10InActive Member
- Jun 2009
- Brandon S.
- 1994 Trans Am
- Houston TX
- 92
I just used the Scan9495 program to get an idle log. Hopefully this helps towards getting me on the right track
https://drive.google.com/open?id=0B8...jVWaXlhVnZqWGc94 Trans Am A4 Almost Stock
