Results 1 to 10 of 46
Thread: 383 won't go Over 1500 rpm
04-28-2016, 08:10 PM #1InActive Member
- Jan 2012
- 1997 z28 383 stroker
- oklahoma city,ok
- 2,859
I have a 383 with 24x and 4l80e and Pcm for less tune, well I drove if for the first time the other day since trans and 24x install and the car won't go past 1500 rpm and when you press the throttle it's sputters and rpm's don't climb but mph increases, at idle it will go to 6k rpm no problem anyone have an idea of what it could be? I'm getting aggravated with this dumb car
Smoke tires not drugs
04-28-2016, 08:43 PM #2"The Rock"
If its trans related @Cahall may have an idea.
OWNER/ADMIN
04-29-2016, 09:14 AM #3LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Does the car still have a catyletic converter? This sounds like it could be a clogged exhaust.
FrankGail C. Cahall
04-29-2016, 09:59 AM #4
It's likely none of the above suggested, but it is probobly the pcm for less tune.
04-29-2016, 06:16 PM #5"The Rock"
04-29-2016, 08:14 PM #6InActive Member
- Jan 2012
- oklahoma city,ok
- 2,859
04-29-2016, 08:15 PM #7InActive Member
- Jan 2012
- oklahoma city,ok
- 2,859
04-29-2016, 08:16 PM #8InActive Member
- Jan 2012
- oklahoma city,ok
- 2,859
04-29-2016, 08:52 PM #9LTx Guru
MPH increasing when the car isn't moving faster would seem to indicate a wiring problem. The 4L80E has dual speed sensors, one for converter input and one for converter output (or second sensor is on output shaft if provided). If the PCM detects excessive slip, doesn't it limit power? Not sure if this has anything to do with the 24X setup. Could these sensor signals be switched?
Just a shot in the dark.Last edited by Injuneer; 04-29-2016 at 08:55 PM.
04-29-2016, 11:27 PM #10The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Did they change the shift solenoid pattern in the tune for the 80e? If not it will act like it's taking off in 3rd gear.
