Results 1 to 10 of 11
Thread: Timing Mark Options
04-24-2016, 07:10 PM #1
Timing Mark Options
I need something to rig up or buy for my LT1. Is anything available that works on a SBC and our motors? Tired of struggling with finding TDC on #1 every time I move the cam sensor.
04-25-2016, 06:46 PM #2The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Pretty much going to have to make something. I plan on making a small plate that will bolt to the timing cover then tap those holes to line up with an adjustable sbc pointer. Some people have said certain holes actually line up but I've not checked to see if it's true or not
04-25-2016, 10:16 PM #310 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
I bought a cheesy adjustable Mr Gasket one from the parts store and gorilla glued it to the opti cap. I used a white zip tie to extend it over the belt and allow belt changes.
I can post pics tomorrow.Last edited by 96LT1355Z28; 04-25-2016 at 10:19 PM.
-Josh
co-owner of BDBRacing.com
NMCA OC 9004
04-25-2016, 10:54 PM #4Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,865
I have the gmpp opti block off plate which has a timing marker on it. Not the most accurate and it's off by about 7 degrees but it works.
04-26-2016, 08:11 AM #5
The hub isn't keyed, so technically it can move a bit and throw the numbers off, unless you have a keyed stroker crank with a keyed balancer.
04-27-2016, 08:58 AM #6
05-03-2016, 08:41 AM #710 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
Here's what I made from this pointer, after doing some trimming I glued it to the opti cap and used a zip tie to extend it. The zip tie gets it closer to the balancer and flexes which still allows the belt to be removed.
mrg-4597_xl.jpg1.jpg2.jpg3.jpg-Josh
NMCA OC 9004
05-03-2016, 10:32 AM #8
If only I had an opti!
Looks like I am gonna be fabbing something up.Correlation does not imply causation.
05-03-2016, 11:01 AM #910 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
I feel you, mines going away in the fall so I'm gonna have to figure something else out too. Keep this thread updated!
-Josh
NMCA OC 9004
05-03-2016, 07:46 PM #10VIP Member
- Nov 2010
- CHRIS
- 94 CAMARO.
- Biloxi, MS
- 1,342
