Results 1 to 10 of 19
04-21-2016, 04:32 PM #1InActive Member
- 1994 Sunfire Yellow Trans Am GT
- Central Virginia
- 24
Fixed an oil leak, now it won't start
My 94 TA has been leaking from the waterpump shaft seal for a few months apparently. Pulled the opti and waterpump yesterday to replace the seals and now the car won't start. It ran fine prior to so something happened, obviously. I'm at a loss as to what's going on. The opti is spline drive and went back on without any issues and sits flush with the timing chain cover. All I'm getting is cranking but it will not turn over. I've done an opti swap before with no issues so this had me scratching my head.
04-21-2016, 04:44 PM #2Lurker
- Sep 2014
- Joel
- Colorado
- 1,157
The statement that you made it cranks but will not turn over. I will assume that the engine is turning over with not spark.
1. Did the opti get wet?
2. Did you check for spark?
3. Check all electrical connections
4. Check for proper voltage at each electronic conector. Hope this will help you solve.
The Following User Says Thank You to Camaro96 For This Post:
04-21-2016, 06:32 PM #3InActive Member
- Central Virginia
- 24
It did not get wet. I've got spark. I checked the opti connection, plug wires, coil plug etc. and haven't come up with anything.
04-21-2016, 07:07 PM #4
I'd reinstall the opti, it's not as hard as people make it out to be to install it off, then check wire routing.
04-21-2016, 07:27 PM #5InActive Member
- Central Virginia
- 24
It's definitely not as bad now as it was the first time. I'm hoping that, worst scenario, my buddy that was helping me plugged some wires in incorrectly.
04-21-2016, 07:44 PM #6Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
04-21-2016, 08:43 PM #7InActive Member
- Central Virginia
- 24
It is Fastbird, it wants to start but just can't quite turn over.
04-21-2016, 09:34 PM #8"The Rock"
Start more simple... does ur battery have enough juice?
OWNER/ADMIN
04-22-2016, 06:37 AM #9InActive Member
- Central Virginia
- 24
Yes sir. It's got plenty of juice. Short of somehow frying the opti or serious spark plug wire routing issues I'm at a loss.
04-22-2016, 07:08 AM #10Lurker
- May 2013
- 6 speed Impy
- 1991 Z-28, 355, HSR, M6--2005 CTS-V (SOLD)--1994 Impala SS 6 Speed Swap--Have all blocks covered.
- Dover De
- 245
Check all connectors. I had a bad ICM connector, would check good sometimes then short out and not work. Wiggle check all connectors. A bad connector cost me 450.00.
Mike
