Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. #11
    If hes gonna leave the motor stock and not require extra tuning... he can use what he has...
    OWNER/ADMIN
  2. #12
    Enrique
    93 Z28
    Houston/Clear Lake
    I agree with Popo.
  3. The Following User Says Thank You to 383z For This Post:
  4. #13
    The FABRICATOR!
    southern illinois
    Yea, where the 93 gets expensive / involved is the tuning. If he's got everything available and it works, by all means run it. It will at least get you started. Then later on if you decide to do some mods you can weigh out changing pcms vs buying the stuff needed to tune the 93. Good thing is, if you've got a working 93 pcm, you can pretty much break even on the conversion and possibly end up with a little bit left over
  5. The Following User Says Thank You to firebird_1995 For This Post:
  6. #14
    Mar 2016
    Adam
    1974 Chevrolet Chevelle
    I plan on staying stock with just headers for now. Thanks everyone for the info. I'm going to plan on using the 93 harness and pcm for now and upgrade whenever my TH350 decides to give up.
  7. #15
    Enrique
    93 Z28
    Houston/Clear Lake
    Your TH350 should last a awhile. The lowest rated TH350 is rated at 410 lbs/ft torque and the 93 Camaro LT1 produced 325lbs/ft.
    I think it depends on how bad you beat on it obviously.
    What would you get if it goes out?
    I would get a 700r4 for overdrive and you still won't need the computer to run it.
  8. #16
    Mar 2016
    Adam
    I still have the 700r4 that was in the 93 trans am since I have the whole car and its running. It'll just need a rebuild since 3rd and 4th slip. That's probably what ill go with once I get this conversion done and I have an opportunity to rebuild it.
  9. #17
    Mar 2016
    Adam
    Does anyone by chance know what headers I can use with the swap? I'd prefer long tubes
  10. #18
    OWNER/ADMIN
    +1
    Keeps life simple, until it's time to tune it.
  11. The Following User Says Thank You to Injuneer For This Post:
