Page 8 of 9 FirstFirst ... 456789 LastLast
Results 71 to 80 of 87
  1. #71
    The FABRICATOR!
    Jul 2011
    southern illinois
    Quote Originally Posted by KLaBZ28 View Post
    hmm I'll look up the specs on the Edge, I'd really like to stay with a Yank I love how that drives just a little too high stall (I was going to do heads/cam but ran out of fun tickets). I would think 3400 might still be a bit high for me. What did it flash to, and is that for the 153 or 168 tooth flywheel? I was thinking of grabbing a cheap vortec flywheel so I don't have to chase down a specific converter style, just get a mini hi torque starter.
    Its the street edge model i believe. It's pretty tight really. I can footbrake it to 2600 and it would flash to 3000. A friend of mine has the same one and it will transbrake to 3400 and flash 3600. It was made to bolt to the factory flexplate.
  2. #72
    Nov 2008
    Methuen Mass
    Quote Originally Posted by myltwon View Post
    How much you want for the yank?
    $450
    95 Z28 hard top - LT1, 4L60e, bolt ons, Yank SS3600, suspension, viking coil overs, 3.42 10 bolt, 3320 lbs - 12.304 @ 108.52mph 1.69 60'
    08 Saab 9-7x - L96 6.0 swap, L92 heads/intake/TB, LS6 cam, LS9 springs, 7.425" hardened pushrods, CAI, 1-3/4" stepped LT's, catback, 4L60E, FTI 3000 278mm converter
  3. #73
    Nov 2008
    Methuen Mass
    Let me think that one over I'll get back to you. It would be pretty sweet to not have to swap the flywheel but I could use a starter too.
  4. #74
    Jul 2013
    Alex Rauld
    1994 Trans Am GT
    Got any pics or a part number?
  5. #75
    Nov 2008
    Methuen Mass
    Yeah I'll PM you.
  6. #76
    Nov 2008
    Methuen Mass
    I still have a pending question here if you guys know - Currently I have an ASP under drive pulley. Is there a recommended pulley to use in combination with the 12 rib setup?
  7. #77
    Nov 2014
    Steve Devillier
    1995 VSR Billet 78/75 Turbo TransAm, 1995 PT76 Z28
    Plaquemine, La.
    Not sure if you ever received a reply, but the ProCharger kit was designed for the stock crank pulley/balancer. I wouldn't use any underdrive pulley with a supercharger. Risking fit and damage to the crank snout for the max of about 7 hp is not worth it. If it's like most inexpensive underdrives, they mount the oem balancer out front, you will not be able to use this anyway.
    Thanks,
    Steve
    Steve Devillier
    1995 TransAm with VSR Billet 78/75 Turbo
    1995 Z28 with Precision 76mm Turbo
    2012 Chevy extra cab pickup
  8. The Following 2 Users Say Thank You to PerformanceSS For This Post:
  9. #78
    Nov 2008
    Methuen Mass
    thanks! I'm probably going to use the stock balancer. As for the hub, I'm doing a 24x conversion first and the billet cover that came with my kit is a non mech water pump provision, bigger diameter balancer hub seal for the BBC OD hub. my question is this, i was thinking to sell the fancy billet timing cover since i am sticking with a single row timing chain, stock mechanical water pump, and an aftermarket engine pro stock OD keyed balancer hub. that way i can save some serious cash by sticking with cheaper hub, cheaper 96 timing cover, no EWP.. but ive done some research and heard people cracking keyed stock OD hubs, so maybe I should keep my fancy ass timing cover and do the lonnies performance bbs od hub and key? overkill for running this thing on the lowest possible boost? orrrr good idea for future insurance incase i build the bottom end down the road..
  10. #79
    Nov 2008
    Methuen Mass
    this project went in limbo because I bought a stupid ls powered car and it keeps breaking. back on the front burner now
  11. #80
    We are using stock balancer, procharger 8.5" crank pulley, and 2.95" blower pulley and procharger dbi0420-012 belt for a 12 rib p600b. Stock snout. Yolo
