Results 1 to 10 of 11
Thread: Hose routing water pump help?
02-21-2016, 01:35 PM #1
Putting a car together for a customer with unknown components and found a weird water pump. It is missing the tube that goes to lower port on the radiator on the driver side? Here's a pic.
I was putting the hoses on and noticed the difference from mine to this one.
Any ideas where this water pump came from? How do I route the coolant hoses now? Can I plug off the driver side radiator port?
94 Camaro Z28 383ci AI Heads LE Cam 4L60E Stock 10 Bolt
Personal Best 10.72 N/A 10.13 NO2
02-21-2016, 03:06 PM #2
Its just the oil cooler line, if you block the lower rad port its fine. That is how my car is setup.
02-21-2016, 04:33 PM #3LTx Guru
Useful guide to LT1 water pumps, courtesy of Shoebox:
http://shbox.com/1/lt1_water_pumps.jpgSOLD - GONE TO A (VERY) GOOD HOME ! - 94 Formula A3+1: 381ci forged stroker - Callies Stealth, Oliver 5.85 billet rods, BME nitrous pistons / CNC LT4 heads / CC solid roller / TH400+GearVendors OD / 4.11 Strange 12-bolt / 300-shot N2O / Spohn Suspension / roll bar / MoTeC M48 Pro engine management system /a few other odds 'n ends.
02-21-2016, 06:27 PM #4
OP
can't see the whole WP in your pic but it appears to be a B or Y body LT1 WP, not F body
BTW, the lower DS bolt for WP gets thread sealer....it goes into a water jacket96 BBB 383/T56
02-22-2016, 08:15 AM #5
02-22-2016, 08:16 AM #6
02-22-2016, 10:13 AM #7
02-22-2016, 12:59 PM #8
if a B-body WP you can loop the 2 smaller hose pipes together as they are for heater. Not sure if you can "cap" them or if they need to circulate
the other two would be for upper/lower radiator hose
since you didn't put the pump on...can you see (from the top) that the coupler is on between WP & TC....it needs to be to make it work.96 BBB 383/T56
02-22-2016, 01:25 PM #9
02-22-2016, 01:25 PM #10
Mine are capped, no issues AFAIK.
I got a rubber cap kit from my local auto part store and used em with hose clamps.Correlation does not imply causation.
