Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: Fuel
    Dec 2012
    Tommy N.
    Silver 1996 Camaro Z28, Green 1996 Camaro Z28
    El Paso, TX
    Default Fuel
    Can the stock system take some race fuel like 5 gallons of 110? Or if you have to change some stuff what is it? My dad wants to run some race gas he's already replacing the fuel pump his was dying at the track Friday and I need to change my fuel filters because I think that's my issue if not injectors.
    I run it in mine all the time. Cats don't like leaded fuel though.
    Lead is also bad for the O2 sensors. Takes a while, but eventually they die.
    Dec 2012
    Tommy N.
    El Paso, TX
    No cats on any of our cars and o2s aren't too bad so race gas is ok to run cool thanks guys
    Dec 2012
    Tommy N.
    El Paso, TX
    @Vicious95Z28 did you see any improvement in times or anything? I just told my dad what y'all said he was wondering if he will gain anything from just adding 5 gallons, the motor is a 383 LE2 heads compression is about 10.5:1 T56 Trans and I think it has 32lb injectors or ford green tops and a mail tune not sure on injectors can't remember
    Doubt honestly that he'll gain much just by adding a lil fuel to it. I honestly can't give you a scientific improvement in my car.
    @Injuneer, are there any O2's that are lead resistant?
    Dec 2012
    Tommy N.
    El Paso, TX
    Ok cool thanks I'll tell him and see if he still wants to try it
  9. #9
    He won't gain any power running race gas provided that his car was running fine on pump.
  10. #10
    Dec 2012
    Tommy N.
    El Paso, TX
    Well he found out the pump is going out so he's doing the trap door fix on it this weekend he already has it cut out
