Page 1 of 3 123 LastLast
Results 1 to 10 of 27
    Default 275/60 vs 295/55 pro's and con's
    So many of you know that I'm working on my 8.8 rear and I have to decide how much I want to narrow. I want to tuck the tire under the car a bit and I like the look of the 295/55, 5.5" bs 10" wheel and narrowed to tuck. I just don't know if I "need" that much tire. I just figured if i made room for it, I'd have plenty of room for a good 28" slick if I need it.
    With the 275 I won't have to narrow quite as much, the problem is if I would ever need anything bigger I wouldn't have enough room.
    Dec 2011
    JeremY
    1972 NovA
    Elsberry, MO
    Have you also checked tire prices in the 295 vice 275?
    I bought a Hawk that had 295's and I went back to 275's.
    '72 Nova "HadeSS"
    Quote Originally Posted by JCzNova View Post
    No, I actually haven't compared, I guess if I kept everything setup for the 275 I could also run a 275/50 if I wanted and not look stupid. I like to keep options open.
    My wheels are 18s... but still a 315 all under the car in the rear. Minor modification to fit. Next round will be 325s for me.
    OWNER/ADMIN
    Lil different for you though, Popo, a drag tire has a totally different type of sidewall with allot more bulging and either of my two tire choices are 28" tall, yours are prolly around 26".
    Using the 10" wide wheel with a 5.5" offset, and narrowing the rear 2" per side would end up with the wheel in the exact same position as my stock width 12-bolt w/ 10" wide, 7.5" BS wheels. This is an M/T ET Drag 28x10.5-15W. It is 28.1" diameter, 13.1" wide. By comparison (assuming M/T ET Street Radial):
    295/55:
    -diameter = 27.8"
    -width = 12.0"
    That would put the outside edge of the tire about 1/2" deeper in the fender, compared to the photo.
    275/60
    -diameter = 28.0"
    -width = 11.0"
    That would put the outside edge of the tire about 1" deeper in the fender compared to the photo.
    Also note that M/T uses an 8" wide wheel to measure the 275/60.
    Narrowing 3" (1.5" per side) instead of 4" would move the 275/60 back to within 1/2" of the photo, but as you already realize, that limits you when looking to go wider on the tires.
    Quote Originally Posted by Vicious95Z28 View Post
    I get it. But my car is also set up on a 2"drop.
    OWNER/ADMIN
    Mine is dropped about 1.5. http://i1155.photobucket.com/albums/...ps022679aa.jpg
    http://i1155.photobucket.com/albums/...ps0a4c8d38.jpg
    I'm going for this. This isn't my car but it represents what I'm going for.
  9. #9
    Do u know whose car it is?
    OWNER/ADMIN
  10. #10
    OWNER/ADMIN
    Popo, the guys name is Chris, he goes by GMRACER13 over on the other forum.
