Results 1 to 10 of 13
Thread: possibly getting a blower
01-06-2016, 08:08 PM #1InActive Member
- Sep 2014
- N/A
- 1995 Camaro Z28
- MN
- 48
Hey guys, found a decent deal on a centrifugal supercharger. Just curious if i should be switching spark plugs when adding some boost? If so what plugs should i use?
Car is a 95 Z28, ported heads and intake, cam (almost all supporting mods), RR, full exhaust.
Thanks!
01-06-2016, 08:29 PM #2"The Rock"
Yes. Colder plugs...tighter gaps... depending on how much boost, minimal changes at the least to ur fuel system... and if alot of boost, even more changes. Also no matter how much boost... LOTS OF TUNING!
OWNER/ADMIN
01-06-2016, 08:35 PM #3
I will be that guy, if you are asking about if plug changing is required, perhaps more research is required before pulling the trigger on boost.
The Following 4 Users Say Thank You to shownomercy For This Post:
01-06-2016, 08:48 PM #4Xtreme Member
- 7,249
Supporting MemberThis, along with a cam change to net power. Most cams will not give you the full benefit of all the work you're doing when adding a blower (shelf grinds), also, a stout fuel system upgrade will be needed if it's already heads/cam with boost added on. I maxed a single 255 and 42lb injectors with a p600b and heads cam. Almost wasn't pretty.
Alot of research should be done, it gets expensive quick
Sent from my SAMSUNG-SM-G900A using Tapatalk2021 Charger Scat 392
01-06-2016, 08:48 PM #5InActive Member
- Sep 2014
- N/A
- 1995 Camaro Z28
- MN
- 48
I have upgraded fuel pump and the only thing left on the list for me is plugs only reason why I came here for the info. Won't be running much more than 6 lbs of boost. how much colder plugs? and how much tighter gaps?
01-06-2016, 08:52 PM #6
I run TR6 plugs and a .035 gap
01-06-2016, 08:56 PM #7InActive Member
- Sep 2014
- N/A
- 1995 Camaro Z28
- MN
- 48
Thanks for the help! I had read before that TR6 was the way to go just wanted some reassurance.
01-06-2016, 09:27 PM #8Xtreme Member
- Apr 2010
- Brian DeLuca
- 1997 Trans Am WS6
- Piscataway, NJ
- 1,297
TR6 will be fine without knowing much more about the setup. What head unit/system are you running?
17 Corvette Z06 - 11.05 @ 125
17 GMC Sierra Denali Dmax
01-07-2016, 04:56 AM #9"The Rock"
I run .028 gap.
OWNER/ADMIN
01-07-2016, 07:15 AM #10Xtreme Member
- 7,249
Supporting MemberBr6ef at .030 for 8ish psi
