Results 11 to 20 of 24
  1. #11
    LTX Regular
    Jul 2013
    Ernie
    97 Mullet
    Minot
    Would the new -8 feed line be from the pump forward?
    355 LT1 Turbo, Ported TFS heads, LE Ported Intake, LE cam, 80lb inj, Dual pumps 340 & 320lph on e85, etc.....
    www.fquick.com/SleepyZ
    <font color=#ff0000>
  2. #12
    Long Live the Opti
    Sean
    1999 Twin Turbo Corvette
    Fort Wayne, IN
    No these are for the under drivers seat connection forward. Essentially the stuff I sell for the standard fuel line relocation kit (break it out behind the drivers strut tower) except with braided stuff. Pump forward is more of a custom job because you could do several different scenarios with it.
  3. #13
    Long Live the Opti
    Sean
    Fort Wayne, IN
    Looks like One of the three intro spots is being spoken for.
  4. #14
    Long Live the Opti
    Sean
    Fort Wayne, IN
    One intro spot is officially taken. I'll have some pics and such up for you guys mid week as I put this kit together.
  5. #15
    Long Live the Opti
    Sean
    Fort Wayne, IN
    @spikester7878 lookie what I have ready for you!
    Everyone, this is the standard -6 feed and return kit. The -8 upgrade will look essentially the same. This is how it'll be shipped. Two assembled hoses, and four adapter fittings, spring lock like you'll find by the fuel pump.
    I'm still working on hard pricing, but looks like I will be able to come in below the $175 I initially mentioned for the base kit as seen here.
    Some notes: This is a relocate length setup, meaning you'll need to drill the back of the strut tower to run them through. They are MUCH more flexible than the nylon line kit I sell though, which is a plus. The -6 fittings will require a MINIMUM hole size of 3/4" to run the fitting through. I HIGHLY recommend going larger and putting a grommet in so there's no chance of the metal cutting through the stainless on the hose (long term abrasion rubbing through).
    Thoughts from anyone?
  6. #16
    Fluid checked for leaks via pressure prior to shipping?
  7. #17
    LTXTech Sponsor
    Dec 2009
    Mike
    1994 formy
    Temple Terrace, FL
    beautiful! Those are going to be sooooo much better than the stock ones.
    383, Eagle crank, scat rods, Mahle pistons, 238/248 .565 cam. 3k stall, AFR 210 heads, Pacesetter LT, 58 MM TB and a few other goodies.
  8. #18
    Long Live the Opti
    Sean
    Fort Wayne, IN
    I don't have a way to do it, but I've NEVER had a -an line I've personally assembled leak. If it leaks, I'll take care of it obviously. I think folks know I support my stuff.
  9. #19
    Wasn't implying you didn't support your stuff, just coming from stuff at work, they assumed it was all good and then what do you know, skydrol everywhere
    Either way, if you are open to varying lengths ever so slightly with minimal cost effect I would be interested.
  10. #20
    Long Live the Opti
    Sean
    Fort Wayne, IN
    Ooh........skydrol. That's nasty shit. We used that on the KC-10. I wiped some up that a crew chief spilled once and my hands were tingling for a while afterwards. I get you though, you think it's all good then....oh crap, leaks. It's a risk I take, but I go in knowing that before hand.
    How much are we talking for length variances? Shoot me a message with what you're thinking.
