Results 1 to 9 of 9
11-20-2015, 06:51 PM #1Lurker
- Dec 2012
- Brad Powell
- 1994 Camaro Z28 M6, LT4
- Lexington, KY
- 34
No fuel pressure...but pumping fuel
So when I have a gauge hooked up and use the prime cord the pump runs and I hear fuel moving at the rail, but no pressure builds. It does this with an aeromotive adj regulator and the stocker. Maybe the pump is bad? Everything on the pump is hooked up correctly. Car was running on jack stands, I shut it off to put it on the ground and now it won't run. It fires periodically, but won't idle. Here's a vid of the prime with a gauge.
Sent from my iPhone using TapatalkLast edited by 9t4zee28; 11-21-2015 at 03:42 PM.
2007 Silverado CC Z71 VortecMax
1994 Camaro M6 Z28. 355 forged 24x LE2 LT4 H/I, LE cam, supporting mods, LT's ypipe, etc
11-20-2015, 07:03 PM #2Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
11-20-2015, 07:25 PM #3Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
Yeah I tried it with the fuel line off the rail and it pumps fuel out
Sent from my iPhone using Tapatalk2007 Silverado CC Z71 VortecMax
11-20-2015, 09:27 PM #4
maybe you could try pinching the return line off while priming it and see if it would try to build pressure then....if it built plenty of pressure at that point blame the regulator, if it builds anything under like 60 i would say somethings up with the pump
11-20-2015, 09:59 PM #5Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
I'll try that in the morning, then look at the pump. I had the stock and the aftermarket adj on it and both don't build pressure, I'm leaning toward pump at this point. Crazy thing is it was idling fine, I shut it off for 2 mins tops and it restarted idling real rough and low rpm then died. Now, if I let it sit for a while, it'll hit, then die immediately
11-20-2015, 10:50 PM #6
Did you take the Schrader valve out
forged 383,9.6:1,280xfi, trickflow heads,edlebrock lt4 intake,moser 12 bolt w/373
11-21-2015, 01:44 PM #7Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
Got fuel pressure...faulty gauge ...got new ICM and still no idling, must be the opti...here's a video of it "running"
11-21-2015, 04:43 PM #8LTx Guru
There are two different types of gauges. A "test pressure gauge" has a pin that depresses the core of the Schrader valve, allowing pressure to reach the gauge. A plain "gauge" does not have the pin, and requires that the valve core be removed, as tleed pointed out above.
11-21-2015, 08:02 PM #9Lurker
- Dec 2012
- Brad Powell
- Lexington, KY
- 34
The pin had fallen out of the fitting and I didn't know it, my plugs are black and gas filled now, so I'll try new plugs before I swap opti's
