Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. #11
    Dec 2011
    Mark
    Altoona, PA
    Finally got my wheels on. Very happy with the look. Lowered back of the car a little. Need coil overs to set the front a little lower. Goal for next year is to make it hook. Suspension changes coming. 🏻
    Front are 15X4 with 2.5 BS. I have 3/16 spacers on the front. 26X6 M/T radials on the front. Rear are 15X10 with 7.5 BS. 275/60R15 M/T ET street Pro's.
    Now they make a front wheel with 1.5" BS but in my opinion they stick out too far. Again just my opinion. This is why I chose to run the 2.5" BS up front with a 3/16" spacer. This sets it back in 13/16" of inch more than the 1.5" which is a lot. Just looks better to me. It's all in what you like and prefer.
  2. #12
    Yessir brother, get that nose lowered and youth be set!
  3. #13
    Dec 2011
    Mark
    Altoona, PA
    Quote Originally Posted by Vicious95Z28 View Post
    Thanks! I could put the front sway bar back on and pull it down some but that wouldn't be any fun. Coil overs will be on next year. At least on the front anyway. Goal is to make it hook next year.
  4. #14
    I've had qa1's on my car for about 7 years now. I hope they're still good, lol!
