Results 1 to 10 of 14
Thread: 4th gen Weld RTS help
11-16-2015, 10:00 AM #1VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
I've searched this extensively and feel as if I'm more confused than ever. I would like to run the Weld RTS with black spokes. Front 15x4 and 15x10 in the rear. Stock width rear.
So rear should be 15x10 with 7.5 BS with stock width rear.
So my question here is Low pad or medium pad?
Front is where I'm really confused. I can't seem to find the exact answer on BS and what pad height to use.
I have the LT1 brakes up front. Do they make a wheel that will fit the LT1 and LS1 front brakes? I don't want something that sticks out past the fenders.
Can someone please provide some insight to clarify? Part numbers would help. If you can provide pics of your setup with the specs that would be great. Thanks for your help!
Sent from my iPad using TapatalkStock bottom end, Impala head gaskets, Stock heads w/stage 2 port polish Comp beehive springs, Crane 1.6 RR's, Thunder Racing cam, Cloyes Billet True Roller TC, Long tubes, custom true dual 3" w/X-pipe, Ported intake with 58mm TB, 36lb injectors, PCMforless chip, Tick Performance stage 3 M6, Strange S60 4:10's True Trac 35 spline axles, MSD complete Ignition system, Summit electric water pump and a ton of other upgrades.
11-16-2015, 05:22 PM #2LTX Regular
- Nov 2011
- Marc
- 1995 Formula
- magnolia, DE
- 400
Pm sent
1995 FORMULA M6
11-16-2015, 07:07 PM #3
I'm interested in this too.
Sent from my SPH-L710 using Tapatalk
11-17-2015, 05:18 PM #4LTX Regular
- Nov 2011
- Marc
- 1995 Formula
- magnolia, DE
- 400
Fronts are 15x4, 2.5 b/s, 0mm offset low pad. Part # 71LB-504B25A.
Which do require a .25 spacer to clear stock LT1 brakes. Fit PERFECTLY. Not sucked into wheel wells, not sticking out. Perfectly flush.
Rears are 15x10, 7.5 b/s, medium pad. Part # 71MB-510B75A.
Fit perfect stock ride height, stock width rear.1995 FORMULA M6
11-17-2015, 06:48 PM #5VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
Awesome! Thanks for the info and part numbers. Time to order some wheels. 🏻
11-17-2015, 08:48 PM #6LTX Regular
- Nov 2011
- Marc
- 1995 Formula
- magnolia, DE
- 400
No problem. Make sure to post pics after you get them on. Your car is gonna look killer with those wheels!
1995 FORMULA M6
11-18-2015, 12:50 PM #7LTx Guru
Out of curiosity, what it Weld talking about when they reference the "pad"? They didn't use that term way back when I bought my Pro-Stars.
11-18-2015, 01:23 PM #8
I don't have to use any back spacing called up weld told them what I have new exactly what I need
11-18-2015, 01:24 PM #9VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
11-18-2015, 01:26 PM #10
