Results 1 to 10 of 18
Thread: blower cam?
08-21-2015, 04:23 PM #1
blower cam?
What is a good cam for a lt1 with a vortech supercharger and stock compression and a 3000 stall convertor . I have an lt4 hot cam that I got before I decided to get the supercharger.
08-21-2015, 06:23 PM #2"The Rock"
For me there was only one choice. I contacted LE and gave him my build info amd he spec'd me a cam.
He is a sponsor here, so if u want to talk to him... @NightTrain66
The Following 2 Users Say Thank You to popo8 For This Post:
08-22-2015, 03:23 PM #3
08-22-2015, 03:37 PM #4The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
I've got one for sale. $125
08-22-2015, 03:52 PM #5
I would go custom spec'd from LE or the likes. May want to consider dropping the compression a bit.
08-22-2015, 04:05 PM #6"The Rock"
08-22-2015, 05:19 PM #7Xtreme Member
- Apr 2012
- Mike
- 96 Z28, 95 Roadmaster
- Conshohocken, PA
- 1,869
The Hotcam would make an alight blower cam. It has a 10 degree duration split favoring exhaust and barely any overlap. I would stick with that honestly. Your engine will be on borrowed time with boost and a more mild cam may help it live longer. Also, you can also get away with a cheaper valvetrain.
08-22-2015, 07:39 PM #8"The Rock"
I missed that. So its s stock motor?
08-23-2015, 08:45 AM #9
Stock bottom end , with new bearing and rings, ported heads with lt4 springs and roller rockers, 53 mm throttle body with 36lb injectors.
08-23-2015, 08:46 AM #10
