Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    Default Please Help Me Diagnose My HID Issue
    Hi all, I'm having a problem with my HID high beams on my 96 TA. I've only had the car since April and the PO said that the high/low HIDs had just been installed not long before the sale. I don't know what brand the kit is. The high beams recently stopped working. Low beams are functioning perfectly. I tried to switch to my high beams one night about two weeks ago and the headlights went out. Blue hi beam light in the dash comes on. I can switch back to lows and they work just fine. I did get the highs to come on once, but they went out after a couple seconds. That was a few nights ago. I have not been able to get the highs to come on since. Any ideas? Please bear with me, I don't really know much about HID lights.
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    They are only two kinds of low/high HID kits. One has a HID lamp for the low beam operation and the other is a small halogen used for the high. The other setup is a single HID lamp with a shield controlled by a solenoid.
    Any chance you can see inside and determination which you have? When you click the highs, does everything go dark or there is simply no change in the output?
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    Quote Originally Posted by blackbirdws6 View Post
    When I switch to highs, the headlights go completely dark. Is there any specific way to tell which type I have? If it was the solenoid type, where would the solenoid be?
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    I just had someone else tell me that the only style for our cars is the shield/solenoid type that uses a magnet. Is this right?
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    Upon further examination of mine, they don't appear to be factory housings. There's the main bulb in the center but there's also a smaller blue one underneath it that angles upward. I'll post a pic. The lights are not on in the photo, that's the flash from my camera.
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    Sorry, the photo posted sideways for some reason.
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Quote Originally Posted by SilverWS6 View Post
    Tells me that you may have the two bulb system. I would almost guess this is a wiring issue if both sides go out and nothing else lights up.
    That is not true.
    I can see the main HID lamp but tough to see anything else. The small lamp on the bottom is called a city light. It doesn't serve any real purpose.
    Can you get the bulb out so we can really see what you have or even a name on one of the HID ballasts?
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    I've looked at both ballasts and there aren't any visible markings, brand names, or part numbers. I'll pull one of the bulbs when I get home this evening.
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
  9. #9
    Apr 2015
    Jaylan Sears
    1996 Trans Am WS6
    Memphis, TN
    I've not been able to find any bad connections in the wiring. I'm really starting to believe that it's the dimmer switch. When I first got the car, sometimes when I'd hit the switch for high beams, they would stay on low beams. Fogs would stay on as well, proving that it stayed on lows. Other times, it would go to high beams, but it would stay stuck on highs even after switching back to lows. When this happened, I would have to turn the headlights off and turn them back on to get back to low beams.
    96 Trans Am WS6
    73 Formula 400
    74 Trans Am
  10. #10
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Were you able to pull one of the bulbs?
