Results 1 to 10 of 11
Thread: Looking for advice!
07-12-2015, 11:43 PM #1
Looking for advice!
What do you guys think about running e85 on a cam/nitrous setup? It would be a 100-125 shot. I have a set of 30lb and a set of 36lb injectors and a 340lph pump and a cc306 cam (Bought a sweet bundle package).
07-12-2015, 11:57 PM #2
@MoeHorsePower
I'm curious if you would have plenty of injector. Maybe Moe can help you out.
07-13-2015, 11:48 AM #3
I have a couple of buddies that run it on their mustangs. I have never done research on how the lt1 handles it or if it likes regular pump gas better.
07-13-2015, 12:00 PM #4
@dawdaw he likes it in his mullet mobile, I would guess you may run out of pump head if your NA power is stout.
07-13-2015, 04:38 PM #5VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
Is this a stock bottom end car ?
Unless your really high compression it's not worth it. Will it work , yes but there are no really gains to be had unless your boosted , or high cimpressuon.
If your absolutely hell bent on running the fuel I can possibly give you a few pointers.
The Following User Says Thank You to dawdaw For This Post:
07-13-2015, 04:42 PM #6VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
If its a stock bottom end car with just a cam 36lb injectors at 3 bar will be enough.
07-13-2015, 05:38 PM #7
Yeah this motor is stock bottom end, just going to cam it and spray it while I build my other motor. But I would like to run more compression on the motor I'm going to build. But I don't know what compression would be best. I'm by no means hell bent on running e85. Unless I can make better power with it.
07-13-2015, 05:51 PM #8VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
There are no real advantages on such a mild set up.
For your next motor depending on what it is yes there a some big advantages. 1.80 a gallon and it will take anything you throw at it. 14:1 compression, 300 shot , larger tuning window, oxygenated so it will make more power then pump gas or non oxygenated race gas, will cool the motor a little bit, .
Overall it's a great fuel and there are a LOT of guys switching to it because at the end of the day who wants to send 8 dollars plus a gallon for race gas when you can put a dirt cheap fuel in it and make more power? I will say there are some very big misconceptions about the fuel so don't listen to your neighbors great grand father that says it eats lines lol.
07-13-2015, 09:29 PM #9
I think I need your number for when I get a little more into this other motor!
07-14-2015, 06:34 PM #10VIP Member
- Apr 2011
- KYLE
- 95 MQBM Z28
- davison michigan
- 3,874
Sure ask any questions you may have about the fuel.
