Results 1 to 5 of 5
    Nov 2008
    1994 Trans Am
    PA, USA
    Default Looking to convert to H4 bulbs
    I've been spending too much time lately shopping for some decent housings. http://www.amazon.com/Hella-165mm-Re.../dp/B000FNJ6FM These look great, but out of stock and I doubtful they even make them anymore.
    What are some decent housings for my 94 bird? Last time I shopped around there were lots of options, but now it's pretty slim and mostly junk. I have no interest in HID's, I just want a decent housing with a regular bulb so i can throw a Silverstar Ultra or whatever in it.
    Also, do I need a relay harness or anything or will one of those plug and play harnesses do the job?
    Hopefully some vendors can chime in with their product offering.
    Nov 2008
    1994 Trans Am
    PA, USA
    I spoke too soon, totally overlooked these:
    http://www.amazon.com/gp/product/B00..._bw_g263_i7_sh
    Harnesses are next. Not sure if something like this will work or if I need something a bit fancier: http://www.amazon.com/Halo-Automotiv...6V2DPD7Q4RGQFQ
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    The first link with the free form housings would be the way to go in my opinion. Check rallylights.com to see if they have them in stock. As for the connector, those will not convert the slanted ground oem to H4. You can depin the factory connector or hardwire in the conversion harness. The latter is more ideal if you don't care about cutting, soldering some wires.
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
    Oct 2014
    jon
    95 trans am
    There were some of these lights with my car when i bought it and i just installed them. I'm not sure where they got the housing from, it was a decent fit. But i had to cut some off the back of the metal housing that the light sits inside of. Pretty simple once you get in there. It may not be an issue with all replacements.
    As for the connector, what blackbird said^^
    I just took the connector apart on mine and plugged in to the bulb. swapped the wires around until i had the high/low correct.
    The lighting really doesnt seem any better, but its more of an even white light instead of like a beam of yellow light
    Nov 2008
    1994 Trans Am
    PA, USA
    Purchased, thanks for your input!
    I may even have a harness that works from my IROC years ago, if not I have some new solder goodies on the way that'll make "light" work of hardwiring.
