Results 1 to 1 of 1
    Mar 2015
    EJ
    95 impala
    Allentown Pa
    Default reverse light problem
    I finished my t56 swap on my 95 impala. Finishing touches was wiring up my back up lights to the half moon switch on top of the column... pink and green wires. I added wire temporarily to test if it worked and they did, but like an idiot i was i did not tape up where i twisted the copper and they accidentally touched... and lights turned off... fuses are good and i moved the existing column shifter over to reverse as its still connected and lights turned un... did my back up switch on my t56 trans go bad?
