Results 1 to 1 of 1
    Nov 2014
    rob
    1993 z28
    West side of chi- town
    Default Jegs window switch / autometer tach w/ shift light issue
    Ok guys here's an issue I'm hoping u can help with, when I have my window switch connected my shift light doesn't work right. I ran a wire directly to the coil for tach signal and tapped the window switch and tach both in to this wire. What do you think? Should I try tapping one of them in somewhere else like at the dash cluster or by the ECM ? Do you think there's a backfeed somwhre and I need an inline diode or resistor? This ones got me stumped. Window switch works fine, so does the tach , just the shift light won't light up, if I disconnect the window switch the shift light works perfect, wtf??? Btw it's a jegs window switch and autometer monster tach.Thx guys
    BUILD THREAD PROJECT "BAIL MONEY"93 Z28 STOCK BOTTOM END/HEADS, MSD COIL, MSD 6AL, MSD 8972 RETARD, L.E. CAM 227/235 565/579 110 LSA, COMP 1.6 RR, PCM OF NC TUNE, PACESETTER LTS, !CATS/EMISSIONS, ORY, DUMPED BULLET, EDGE 3600 STALL, 3:23 10 BOLT, LCAS, RELO BRACKETS, PHB, 125 SHOT - (ALMOST READY TO SPRAY....)
