Results 1 to 9 of 9
    Mar 2015
    tk
    1994 firebird formula
    Default iron vs aluminum headed engine
    Hey my formula has a iron headed lt in it what do these dyno at stock as compared to a aluminum headed engine
    Project phoenix
    94 formula a4 Iron headed lt1 1.5 roller tip rockers LT headers
    Well unless someone put iron heads on ur lt1... that motor is out of a b-body. If im not mistaken... those were about 265@ the crank.
    @TubbyFormy
    260 hp crank 330lbft crank
  4. The Following User Says Thank You to SSlowBoat For This Post:
  5. #4
    The Nitrous Outlet Junkie
    Apr 2010
    Troy
    moore, ok (south okc)
    the iron heads flow better than the aluminium heads stock to stock.... but the iron heads are about 20lbs heavier each side and hold heat better (heat soak) the reason it makes less power is the cam in the b-bodies is way smaller the the f-body and corvette cam.
  6. The Following User Says Thank You to zooguy For This Post:
  7. #5
    And press in studs for rockers
  8. #6
    Mar 2015
    tk
    The reason I got this motor is because when I bought the car the engine had low compression I got this engine from a running trans am and when they pulled it that's when I realized that It had iron heads
    Project phoenix
  9. #7
    Apr 2015
    Jon Becker
    1995 Trans AM
    Birmingham, Alabama
    Ha! That motor has been around the block a few times!
  10. #8
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    The flow difference is marginal between the two. I think it's like a 10 cfm advantage on the intake for the iron heads but the aluminums are inherently better because smaller chamber and screw in studs.
  11. #9
    The FABRICATOR!
    Jul 2011
    southern illinois
    Anytime I look at an iron headed lt1 I always check to make sure it says "5.7" on the back and now "4.3". I bought a baby lt1 by accident once. Fortunately the guy (after convincing him they did exist) gave me a generous portion of my money back.
