Results 1,411 to 1,420 of 1507
Thread: Dan's Money Pit NYTRDR
07-22-2017, 10:15 PM #1411Xtreme Member
- 7,249
Supporting Membercould've been your hesitation too if it was loose and moving
still begging for a driving clip of that exhaust. have one of your stance buddies take one from outside the car please, I want it but not if it sounds like shit. your car is fairly close to mine in cam etc
07-22-2017, 11:52 PM #1412Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
14.307@98.21, 2.155 60'
The Following User Says Thank You to Dan For This Post:
07-23-2017, 11:32 PM #1413Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
@<u><a href="http://ltxtech.com/forums/member.php?u=5592" target="_blank">Tubby Z28</a></u>
Here's a video of me driving around with it. Used my phone with it attached to the ttop glass
Outside videos coming tomorrow
Sent from my SM-G920V using TapatalkLast edited by Dan; 07-24-2017 at 02:28 PM.
07-24-2017, 12:13 PM #1414Xtreme Member
- Mar 2015
- Mike Storm "Stormy"
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
That your girlfriend in the video? And shouldn't you close that bag the money is flying out of the car.
07-24-2017, 02:27 PM #1415Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
LMAO I DON'T KNOW HOW THAT HAPPENED
HERE'S ACTUAL VIDEO
07-24-2017, 05:09 PM #1416Xtreme Member
- Mar 2015
- 1995 Trans Am
- Washington
- 1,020
- Blog Entries
- 1
Sounds good there was some wind noise but you can hear it. No like mine where it's Soo loud I piss people off.
It's not how fast you mow. It's how you mow fast.Last edited by Stormyweather; 07-24-2017 at 05:11 PM.
07-24-2017, 07:03 PM #1417Xtreme Member
- 7,249
07-24-2017, 10:02 PM #1418Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
One of my fog lights decided to fill with water. So instead of buying a used one that will probably leak, I went hunting on ebay for a replacement.
Here is the link to them. http://www.ebay.com/itm/201261109542
Basically, all I did was use two hex cap m6x1.0-30 and two 3/4 inch spacers to bolt the lights to the stock fog light brackets. Then, wired them on to start harness.
They fit my new style headlights quite well and the output on them is way better than stock.
07-29-2017, 03:06 AM #1419Lurker
- Jan 2014
- Daniel
- 1996 Camaro Z28
- Bay Area California
- 485
I'd consider myself lowered quite a bit and the only thing that scrapes is the collector or the rear section just before it goes over the rear end and typically only on severe dips on the highway. But of course I'm on a custom TD set up so it doesn't do much for those interested in the SE kit. More so commenting on lowered car with TD's for reference. Made up from a uni x pipe kit and magnaflow merge up and over out through CME.
Here's another pic. And yes I got the hanger fixed on the right side since it was sagging.
Sent from my iPhone using TapatalkArctic White 1996 Z28. Stock internal LT1, CAI, LM1, MGW Shifter, 3.73's, some suspension junk, and shiny salad shooters (retired). Forgestar F14's 18x10 on all 4. Fun stuff coming soon. Also, Cali smog regulations suck...period. **Insert witty quote here** LT1FTW that is all. Have a nice day.
The Following User Says Thank You to SJx408 For This Post:
08-02-2017, 03:31 PM #1420Xtreme Member
- Mar 2015
- Dan Dalessandro
- 1997 Camaro Z28
- 2,211
If you didn't see my other thread on my first road racing event, I'll just give a quick run down.
Went to my local road track and had a blast.
I decided it was time to replace the old pioneer head unit with something more 2017. Ended up getting this BOSS double din setup through Crutchfield for $167.. Came with the new faceplate and everything to make it a painless install. Very pleased with it!
