Results 1 to 9 of 9
    Mar 2015
    EJ
    95 impala
    Allentown Pa
    Default 6 speed in process
    hey guys,
    Im new here and i know this swap has been done many times with great results. But i have a 95 impala ss that i have been working on the last past month. Im doing the t56 swap and its been a fun project as i get a few hours a week of play time with. Besides the f2b kit and bowtie overdrive x member, all work is being done by me. First american car ever! And why not start with a chevy(an impala if that).. center console i used is from a 96 impala ss. took pretty long to make and still have to finish but just reupholstering and spraying it with sem medium grey to make it look oem(hopefully). tunercat will be used in this swap also. I will be doing my steering wheel and column plastics as well. i have pretty much everything besides clutch fork and shifter.
    But here we go with the pics... sorry for shitty and mismatch shots.. will take more once i go under the car. thanks and i hope i can learn more and get tips from fellow members..
    May 2013
    6 speed Impy
    1991 Z-28, 355, HSR, M6--2005 CTS-V (SOLD)--1994 Impala SS 6 Speed Swap--Have all blocks covered.
    Dover De
    Nice Job, you will love it
    Mike
    Wow... welcome and nice documentation so far. Keep the pics progress comming.
    Mar 2015
    EJ
    95 impala
    Allentown Pa
    Thank you, i apreciate it.. i did more to the interior this weekend, but nothing too crazy. Center console 75% done, sem'd the airbag and steering wheel..
    Nov 2010
    SoFla
    Looking good. Have you taken the car for a ride yet? Curious as to how it's feels to you. Loving the center console. I need to find a set of 40/40 seats and install one.
    Curious. What transmission Cross member did you use?
    Mar 2015
    EJ
    95 impala
    Allentown Pa
    Thanks, Still havnt put the tranny in, and the crossmember is from bowtie overdrives.
    Quote Originally Posted by 95ImpySS:429294
    Apr 2012
    Mike
    96 Z28, 95 Roadmaster
    Conshohocken, PA
    The T56 makes these cars a blast to drive. Definitely the best mod you can do to a b-body.
    Mar 2015
    EJ
    95 impala
    Allentown Pa
    Default a little more work
    Had time to do a little more work.. this time cutting the column shifter bracket out and painting the column.. also pulled the driveshaft and crossmember out
  9. #9
    Feb 2013
    Rob Milton
    1994 Formula M6
    Plover, WI
    Man, have you got GREAT timing!! I was just offered a great deal on a '95 Imp SS roller. Car is in amazing shape. The guy had it for a few weeks, and decided he was going to build some massive TT big block for it, got half way done, and ran out of money. Car is complete minus motor and trans.
    I'm in the process of turning my Formula into a nasty drag car, so the plan is to yank out the 355 LT1 and t56, rebuild the T56, and swap it all over to the Impala is a hot cruiser/driver. The Formula is getting the LS1 coil swap, and a built 4l80 to hold the turbo. So, I'll have literally the entire setup, plus a few choices in rear gears for the Imp.
    You sir, have saved me a bunch of time searching.
