Results 1 to 2 of 2
Thread: Versa Fueler
    Default Versa Fueler
    Just wanted to give you all and FYI, if you use a driver box for low impedance injectors and loose pulse width, check your driver box, My car just shut off, starting testing, fuel pressure, spark, harness, pcm then I thought, oh hell the opti, but i decided to bypass the box and she started right up, so make sure you check this first and save you a lot of headaches...
    Good advice. Thanku Moe
