Results 11 to 20 of 32
  1. #11
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    Quote Originally Posted by SwampWS6 View Post
    Will 96lbers be enough to get close to 700rwhp? Last thing I want is to be short on injector. In the process of getting rid of the 80lbers
    talk to your tuner... if he's a decent tuner and tuned a fair share of boosted cars he should be able to point you in the right direction on sizing.... the 80 will probably work on 8lbs ... turning it up to 4 bar will put that injector just a hair above 92lbs...
    i'd get the correct size one's in first so you don't have to go threw getting the car tuned twice.. would suck to have to find out you ain't got enough injector...
    if i were to guess your'e looking at 120's but do not take my advice, call your tuner!
  2. #12
    55 rail pressure with a 65psi rise assuming 1:1 and 10psi of boost gets you 80% DC on 80# sticks with E85 and a "700whp"
    I would say you will either make it, or just be a hair over "safe" area on those injectors. I say run em, pumps are cheaper than good quality high Z 120# sticks
  3. #13
    The FABRICATOR!
    Jul 2011
    southern illinois
  4. The Following User Says Thank You to firebird_1995 For This Post:
  5. #14
    Oct 2014
    Aaron
    1997 Trans Am WS6
    Going to a 24x conversion. How much do you think it will affect my numbers?
    Check out my 97 Turbo Trans Am Build Here --> = B( . )Y( . )STED
  6. #15
    Dec 2014
    john
    camaro
    You need to use a fuel injector calculator like the one posted above, but with your calculated fuel pressure.
    I think 80s will run close to 700whp with your fuel pressure.
    You always want more injector than you think you need.
    Running 24x, will give you more drive-ability, it will give you the ability to run a custom OSmeant for boost unlike the archaic stock pcm, a tuner would likely be more comfortable running a more aggressive tune. I would guess you would gain more power under the curve and gain peak power.
    I wouldn't swap for a power gain so much as reliability tunability. Getting misfires(opti) under boost will end your fun fast.
  7. #16
    Oct 2014
    Aaron
    1997 Trans Am WS6
    I am currently searching for 1000cc injectors right now. I have sold the 80s , so they are non existent. The whole opti deal is really making me think. The 24x will allow me more room for error. And like you said it will allow me to run a more aggressive tune and gain more power under the curve and also make peak hp. The more power I make the deeper I could get in the 10s. May even break into the 9s if I try hard enough (which I will).
  8. #17
    Nov 2013
    Guillaume
    95 Caprice & 89 RX7
    Montreal, Qc
    24x sensor kit with Holley Dominator EFI for LS1 would be perfect
    1989 Mazda RX7 Turbo II, 357ci LT1, AI TFS CNC heads, Garrett GTX4708R, Ford 8.8" SAS, TH400. (Current project)
    1995 Chevy Caprice, Twin turbo 357ci LT1, 9.96 @ 141.2 mph (sold)
  9. #18
    Oct 2014
    Aaron
    1997 Trans Am WS6
    Quote Originally Posted by GuillaumeC View Post
    LMAO pockets not even fat enough. They on a mean ass unforgiving diet right now. Lol
  10. #19
    Here ya go, have fun with dem billz...
    http://injectordynamics.com/injectors/id1000/
  11. #20
    Oct 2014
    Aaron
    1997 Trans Am WS6
    Ha. Yea I know about those guys. I can get a slightly used set for $700 right now. Trying to figure out if I wanna bite that bullet
