Page 1 of 4 1234 LastLast
Results 1 to 10 of 32
    Oct 2014
    Aaron
    1997 Trans Am WS6
    Default I guess I will play to. WHP numbers? UPDATE - 01/10/17
    Well mostly everything is in my sig as far as specs goes. I am going to the dyno in a month or so and would like for your gestimates. This is my 1st build so I extremely excited into seeing what it will do. Heres a basic run down:
    383ci
    LE TFS 215cc
    LE ported intake
    LE 226/226 565/565 114LSA
    Moser 12 bolt 3.42s
    TH400
    billet S480
    Gate set on 8lbs
    10:5 CR
    ID1300 sticks w/E85
    Ask if you need more details.
    Check out my 97 Turbo Trans Am Build Here --> = B( . )Y( . )STED
    Apr 2010
    Brian DeLuca
    1997 Trans Am WS6
    Piscataway, NJ
    Shot in the dark but maybe 500rwhp on 8 lbs.
    17 Corvette Z06 - 11.05 @ 125
    17 GMC Sierra Denali Dmax
    The FABRICATOR!
    Jul 2011
    southern illinois
    Looking at a max of 550-600ish on those injectors at base pressure. Keep an eye on your duty cycle and crank the pressure up if you have to. Looking forward to the results
    Apr 2011
    KYLE
    95 MQBM Z28
    davison michigan
    Yeah^^^ I highly doubt those 80s Are going to cut it on e85... like chris said raise the pressure on them to 4 bar to start out.
    My shot in the dark, 537/611
    Oct 2014
    Aaron
    1997 Trans Am WS6
    Thanks guys. So I am happy with hopefully being able to hit 500rwhp on at least 8#s. But like stated above, I have came to the conclusion that 80#ers will fall shy of the hp I need. So should I go for 96#ers or should I do 120#ers? I can try to see if someone is interested in them and try to upgrade them while I can.
    The FABRICATOR!
    Jul 2011
    southern illinois
    What's your end power goal?
    Oct 2014
    Aaron
    1997 Trans Am WS6
    At least close to 800rwhp. Something where i could get into the 9s
    Mar 2009
    IN
    Crank the base up to 60 if the pumps will let ya without killing flow.
    545.
  9. #9
    Oct 2014
    Aaron
    1997 Trans Am WS6
    Will 96lbers be enough to get close to 700rwhp? Last thing I want is to be short on injector. In the process of getting rid of the 80lbers
  10. #10
    Nov 2013
    Guillaume
    95 Caprice & 89 RX7
    Montreal, Qc
    592 whp @ 8 psi
    1989 Mazda RX7 Turbo II, 357ci LT1, AI TFS CNC heads, Garrett GTX4708R, Ford 8.8" SAS, TH400. (Current project)
    1995 Chevy Caprice, Twin turbo 357ci LT1, 9.96 @ 141.2 mph (sold)
  11. The Following User Says Thank You to GuillaumeC For This Post:
