Results 21 to 30 of 100
Thread: 2015 LTx Modified P/A Rules
11-29-2014, 07:06 PM #21The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
Do you feel the ls1 PCM is just as capable as the aftermarket ECM's?
11-29-2014, 07:13 PM #22LTXTech Sponsor
- Feb 2009
- David
- 1985 Camaro Z28/1994 Firebird Formula
- MO
- 918
I guess that is where my confusion in your statement is. In my opinion I don't believe the 24x is considered "aftermarket EFI". Did it come as a factory option on these cars? No, but there is many things in this class that were not a factory option on these engines/cars. I was under the impression this was the modified class.
-David-
11-29-2014, 07:15 PM #23
yes....at least as far as to carry the same weight penalty...will it do everything that the FAST or Big Stuff will do, no...but it is light years ahead of the LTx pcm and opti
I approved the rules as written and posted ....I have yet to see any LTx car come with the 24x system form the factory...the purpose of the penalty for Aftermarket EFI and carb, was to give a small break to anyone still running the OE PCM....the 24x cannot be allowed to run heads up against the OE system1994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
The Following User Says Thank You to Chopstix For This Post:
11-29-2014, 07:18 PM #241994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
11-29-2014, 07:21 PM #25The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
11-29-2014, 07:24 PM #26
...24x carries a weight penalty in Extreme street as well....the issue is it should carry a weight penalty in modified as well...the rules state it exactly that way
11-29-2014, 07:38 PM #27LTXTech Sponsor
- Feb 2009
- Brad
- 1979 Monte Carlo
- Moscow Mills, MO
- 1,061
- Blog Entries
- 1
If it is that much of an advantage what is the weight penalty going to do?
We are trying to get car count, especially the turbo guys to show up.2013 King of Street & ES/PA Champ
1979 Chevy Monte Carlo 383,Stock Ported Heads, 4L80 with Edge converter, QP 9", Nitrous Outlet Plate Kit
Certified Performance & Auto Repair Inc.
11-29-2014, 07:41 PM #28
200# is a 1-2 tenth difference...can the aftermarket EFI system make up that difference, absolutely...you guys are splitting hairs over something that the rules clearly state...aftermarket EFI carries a 200# penalty.
so the question is...Is the 24x the OE equipped PCM on the LTx platform...if it isn't, which we all no it isn't...it carries a 200# penalty.1994 Formula, 396cid, AFR 227's, Single plane, and 2 of the big ones.
11-29-2014, 07:43 PM #29The FABRICATOR!
- Jul 2011
- Chris
- southern illinois
- 7,164
I can't see penalizing a MODIFIED car (next step outlaw) for a 24x system. How about a weight break of 100# for lt1 pcms?
11-29-2014, 07:43 PM #30VIP Member
- Nov 2010
- CHRIS
- 94 CAMARO.
- Biloxi, MS
- 1,342
What about 100 lbs for 24x. I do agree it is a big advantage over a stock ecm but it's not nearly as good as a aftermarket ecm.
The Following User Says Thank You to BIG CAT For This Post:
