Page 2 of 10 FirstFirst 123456 ... LastLast
Results 11 to 20 of 100
  1. #11
    The FABRICATOR!
    Jul 2011
    southern illinois
    LS1 PCM considered "aftermarket"?
    No it is not
  2. The Following User Says Thank You to firebird_1995 For This Post:
  3. #12
    awwwwwwwwwww yea!
  4. #13
    Mar 2009
    IN
    I'm in.
  5. The Following User Says Thank You to Ryan Stout For This Post:
  6. #14
    Oct 2008
    Jim
    1996 Z28
    Sugar Grove IL
    So looks like this is where i will be at and not in outlaw. Guess i better get car on a small diet with the added 200 lbs for aftermarket computer. This should be an interesting year....
    1996 camaro Z28, Clayton racing 398, Rossler TH350 rmvb with brake, FTI billet race converter 4400, Dana S60 with 4.10's, 300 shot, Accel DFI controlled, UMI, Spohn, PA racing, QA1's, Baer brakes, 325/45/17 M&H, Caged, Corbeau's, Simpson, etc.
    From zero to fuck yeah in 3 seconds.
  7. The Following User Says Thank You to JPack For This Post:
  8. #15
    Nov 2010
    CHRIS
    94 CAMARO.
    Biloxi, MS
    rules look pretty good guys.
    my 2c and a few words of caution. a t6 88 will walk all over a ysi or f1a. the f1a should be bumped up to f1c(old) to be on level footing with the ysi. the new f1c looks to be significantly better than the old ones. the mid frame 80's should be able to hang with the ysi/f1c cars. the n2o should have some kind of jet size limitation. i'm not up to speed so i can't say what would be a good starting number.
    http://ltxtech.com/forums/image.php?type=sigpic&userid=3572&dateline=1317253  626
  9. The Following User Says Thank You to BIG CAT For This Post:
  10. #16
    I also cant understand how an aftermarket EFI system can be allowed to run without the penalty, doesn't make a lot of sense.
    http://ltxtech.com/forums/image.php?type=sigpic&userid=241&dateline=12653889  02
  11. #17
    LTXTech Sponsor
    Feb 2009
    David
    MO
    Quote Originally Posted by Chopstix View Post
    Did you not read the rules?
    -David-
  12. #18
    Why would an aftermarket pcm get a weight penalty but an LS pcm does not?
  13. The Following 2 Users Say Thank You to joelster For This Post:
  14. #19
    Mar 2009
    IN
    All I gotta say is make up your mind quick with the turbo. I'm a t6 88mm now but I'll sell it and go 80 if I have to.
  15. #20
    yes I did...the rules state: Aftermarket EFI PCM and Carburetors are allowed with a 200lbs weight penalty.
    but then this was posted:
    No it is not
    the 24x is as much an aftermarket EFI system as any of the others as it was never offered by GM on this platform, and requires aftermarket parts to make it work.
  16. The Following User Says Thank You to Chopstix For This Post:
