Page 1 of 10 12345 ... LastLast
Results 1 to 10 of 100
    LTXTech Sponsor
    Feb 2009
    David
    MO
    Default 2015 LTx Modified P/A Rules
    Modified P/A
    Qualifying, Ladder, and Tree Information
    Limited to quickest 16 qualifiers. Sportsman Ladder. .400 Pro Tree
    Vehicle/Body Rules
    Open to all year, make, and model vehicles. All vehicles must be stock bodied and stock appearing.
    Minimum race weight including driver 3100lbs.
    Engine & Drivetrain Rules
    Must have LT1 based engine (Factory LT1 Block). Cylinder heads must retain the factory 23 degree valve angle, Trick Flow 21 degree heads permitted (TFS-30400008-M54). Aftermarket heads and converted small block Chevrolet heads will be permitted if they follow the above guidelines.
    Aftermarket EFI PCM and Carburetors are allowed with a 200lbs weight penalty. LS1/24x PCM conversions allowed with 100lbs weight penalty. Gasoline or E85 Only. Rear mounted batteries must be mounted and vented per NHRA specifications and have a functional disconnect switch.
    Any GM transmission allowed. Torque converters not permitted with manual transmissions and clutch activated automatic transmissions are prohibited. Line locks, trans-brakes and two-steps allowed. Throttle stops, delay boxes, and auto shifters prohibited.
    Any automotive rear axle permitted.
    Power Adder
    Nitrous: Maximum number of one stage permitted. Nitrous and fuel solenoids must be visible. Purge must exit engine compartment. NHRA permitted bottle heating only.
    Supercharger: Maximum YSi or F1A. Roots style superchargers limited to 1575 cfm. Supercharger compressor wheel must be constructed of cast or billet aluminum. Exotic materials prohibited.
    Turbo Single: Maximum 88mm inducer and maximum T6 flange. Turbocharger must be of conventional impeller and housing design and type. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic materials prohibited. The tips of the impeller wheel may not be stepped, cut down, or notched to meet impeller tip to tip dimensions. Reducers prohibited
    Turbo Dual: Maximum 60mm inducer and maximum T4 flange. Turbocharger must be of conventional impeller and housing design and type. Turbocharger compressor wheel must be constructed of cast or billet aluminum. Exotic materials prohibited. The tips of the impeller wheel may not be stepped, cut down, or notched to meet impeller tip to tip dimensions. Reducers prohibited.
    Wheels & Tires
    Any automotive wheel permitted. Tires must have a maximum height of 30” and a maximum tread width of 10” for bias-ply and radial tires.
    Class Safety Requirements
    Vehicle and driver must meet NHRA certifications for time and speed the vehicle is running.
    -David-
  2. The Following 2 Users Say Thank You to DMBlack For This Post:
  3. #2
    "Project Storm Trooper"
    Tony
    93 StormTrooper Z28
    Rapid City, SD
    i will assume that the same rules stand for meth/water? seen as a 2ed p/a when used with a FMIC?
    Official Member of $30k Club ​- Work in progress
    1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
    1987 Iroc-Z - Stock Summer DD
  4. #3
    The FABRICATOR!
    Jul 2011
    southern illinois
    meth, while it could be viewed as a second power adder, is mostly used for piece of mind in boosted setups, as high octane fuel in a standalone nitrous enrichment fuel tank on nitrous setups is. We want the people that run these setups to have piece of mind to show up on race day
  5. The Following 3 Users Say Thank You to firebird_1995 For This Post:
  6. #4
    Sooooooooooo, all teh meth is legal and max timing?
    Lame.
  7. #5
    The FABRICATOR!
    Jul 2011
    southern illinois
    Lame.
    If you want to take advantage of the power meth has to offer in being able to run more timing, go for it. I'd personally rather run it and not need it than need it and have it fail. I know you know how much pistons cost.
  8. #6
    I am just being difficult for the sake of it.
    Pending weather, my car will have a nozzle or two spraying. Should go 9s without it though.
  9. The Following User Says Thank You to shownomercy For This Post:
  10. #7
    The FABRICATOR!
    Jul 2011
    southern illinois
    Cool. Looking forward to seeing it on the track!
  11. The Following User Says Thank You to firebird_1995 For This Post:
  12. #8
    Tony
    93 StormTrooper Z28
    Rapid City, SD
    so it looks like i won't get bumped in to outlaw!
  13. #9
    The FABRICATOR!
    Jul 2011
    southern illinois
    Quote Originally Posted by CamaroZGuy View Post
    Nope. Now you have to show up. Should be a great year for mod!
  14. #10
    LS1 PCM considered "aftermarket"?
