Results 1 to 5 of 5
Thread: Which shift kit?
11-13-2014, 03:55 PM #1InActive Member
- Jun 2013
- Colton Waggoner
- 1995 DCM Impala SS (Nightmare)
- New Palestine, IN
- 184
Which shift kit?
Alright looking to see what shift kit is the best out there. Would be going into a stock 4L60E with a Yank SS 3600 until I can afford a transmission package from Frank to go with my NEXT build. I did some reading and the Trans Go kit is said to damage stuff, but people still love it. People also have loved the B&M shift kit too, and it doesn't "destroy" components. It is going into a 1995 Impala SS. Car will be raced and beat on. Looking for input to this, as I don't know much about transmissions.
1995 DCM Impala SS
"Nightmare"
Follow my build thread!
http://ltxtech.com/forums/showthread...tory-and-Build
11-13-2014, 04:06 PM #2LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
The TG kit tears stuff up. They have absurd thoughts on accumulation and the way they have you modify the TCC regulator valve causes converter damage. A "double shift" is also a common complaint of the TG kit. Unfortunately there aren't really any good packaged shift kits for the 4L60E. None of them correct all the issues, and many of them go about "fixing" them incorrectly. The only one that is close to being useable is the Superior (Shift Technologies) kit
Gail C. Cahall
11-13-2014, 04:19 PM #3InActive Member
- Jun 2013
- Colton Waggoner
- New Palestine, IN
- 184
Which shift kit?
@Cahall would a tune to change the shift points be the better option than even getting a shift kit at all?
1995 DCM Impala SS
"Nightmare"
11-13-2014, 08:07 PM #4LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Changing shift points through the PCM is fine, but raising pressure through the PCM isn't. The pressure control solenoid works off a 12 volt reference. If the trans loses voltage for any reason, the solenoid defaults to max pressure. Raising pressure through the PCM really only reduces the voltage to the solenoid. The problem with throwing a "blanket pressure increase" in a 4l60E is that it will usually damage parts. The most common failure in the early 4L60Es is the aluminum forward piston. The higher pressure causes them to crack. We do internal pressure modifications to raise the pressure where and when the trans actually needs it, instead of raising it across the board like raising it through the PCM does.
Gail C. Cahall
The Following 2 Users Say Thank You to CPT For This Post:
11-13-2014, 08:42 PM #5Xtreme Member
- 7,266
Supporting MemberGo figure, that double shift is what my bird did, I just got ahold of the guy that had the 94 the trans came from, and he said he thinks it had a tg kit
