Results 1 to 10 of 16
Thread: 24x converstion
10-22-2014, 08:39 AM #1
24x converstion
So if i were to convert my car over to an ls1 pcm and i have to get emissions for the car how would they keep the year in the computer the same
10-22-2014, 09:12 AM #2
I have read that the 0411 pcm will accept any vin programmed in to it. the biggest problem I see is that it's not designed to work with the canister purge and egr solenoids of the LT1.
10-22-2014, 10:07 AM #3
It will have none of thoughs things on it
10-24-2014, 06:59 PM #4InActive Member
- Nov 2013
- 1997 K1500, SS/SB
- Kansas
- 199
what does your state do to certify emissions, some states just plug into the ALDL and check for fault codes, others do a visual. if yours does the ALDL then you are in you just turn the unwanted fault codes off, bingo you pass!! as far as visual, if you remove everything that remotely indicates something is missing ???? might work ???
P.S. ya might want to wate a bit see if my MagnaTronix Mod works.
10-24-2014, 07:45 PM #5
10-24-2014, 11:04 PM #6InActive Member
- Nov 2013
- 1997 K1500, SS/SB
- Kansas
- 199
you are in dude, switch to the 411 and get it setup.
12-07-2014, 07:57 PM #7
So I need some help with this conversion for efi now the harness with one do I get and can the harness take the 5.3 truck plugs and computer or do I need ls1 coils and computer
12-07-2014, 09:06 PM #8Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,440
I got my entire 24x setup through BP Automotive. He sold me a custom harness, new truck coils with coil brackets, PCM, and the EFI Connection 24x kit. The harness is literally plug n play and awesome quality, plug provisioned for the electric water pump and lengthened so the PCM can mount in the glove box.
A truck harness would need to be reworked. You will need LSX coils, and truck coils are usually fairly cheap and easy to find. I have under 1k into my 24x conversion, which is just a few hundred bucks more than an MSD optispark or Dynaspark.
12-07-2014, 09:46 PM #9
No what I'm asking is would truck coils work on a 24xconversion harness from efi and would the truck computer work
12-07-2014, 10:17 PM #10Xtreme Member
- Nov 2008
- Chris
- 1994 Trans Am
- PA, USA
- 2,440
If you bought the harness from them, truck coils should work and a truck PCM. The 0411 PCM is desirable and a guy on TGO is selling em for $48 shipped. http://www.thirdgen.org/forums/lsx-l...x-ecms-x3.html
A lot of LSX stuff is interchangeable. I recently sold some high energy truck coils to an LS guy. If you have any Q's about what to use and not use use with that harness, I'd recommend contacting EFI. Their phone support is great.
