Results 21 to 29 of 29
05-02-2015, 12:49 AM #21
Screenshot_2015-05-02-00-35-17.pngScreenshot_2015-05-02-00-35-21.pngScreenshot_2015-05-02-00-38-23.pngScreenshot_2015-05-02-00-37-02.pngIMG_3387723278313_wm.jpg
I did a better job with the wires. I just don't have a picture of it how it looked finished. Im still running the a/c condenser and stock ls1 fan assembly.
02-10-2017, 10:28 AM #22
Getting some work done.... finally!!96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
02-10-2017, 10:32 AM #2396 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
02-10-2017, 12:18 PM #24
No room to run stock fans behind radiator now?
02-10-2017, 03:26 PM #25
Nope.... can't tell from the pics but my turbo is inches from the radiator.... you can barely see the turbo over the top of the radiator
02-10-2017, 06:23 PM #26
Anybody run a over the radiator intake set up on here ??
I have my setup on my Motor but still haven't gotten to test fit in car since motor is still on stand , my piping is 4" so maf sensor is my issue . Anybody know if deleting my maf and getting speed density tune will be okay on AI heads , Cam 238/242. 11:5:1 cr
02-11-2017, 09:00 AM #27VIP Member
- Dec 2011
- Mark
- Altoona, PA
- 809
02-11-2017, 09:47 AM #28Xtreme Member
- 7,266
02-11-2017, 08:19 PM #29
I actually bought a setup like a year ago and it came with 4" piping all ready complete , I guess this is the wrong place to post since I know I'll definitely need to lean the radiator back lol , thanks for the info though I think I'll shoot for a good speed Density tune and the car will only be driving on weekends anyways and no big climate changes
The Following User Says Thank You to LTX_TY_ For This Post:
