Results 11 to 20 of 29
  1. #11
    Oct 2013
    Evansville, IN
    Looking for steam pipe location alternatives.... I can weld a bung to the radiator if needed, but can I tap into the water pump or elsewhere??... Pictures please.
    96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
  2. #12
    Aug 2013
    1994 z28 2005 gxp
    Wentzville, MO
    Quote Originally Posted by musict View Post
    I went with the GRI-55241-X...
    not it sure about the ports on the water pump. I'm still using heart core, but ditched the A/C box.... Going to ditch the heater now though as I never drive during the winter. Any idea of what to do with the smaller hose from radiator to water pump??
    thanks for sharing the pics..... My radiator came in damaged from Summitt so I have more time to look for ideas.
    just ordered that one as well...
  3. #13
    Oct 2013
    Evansville, IN
    Bumping this back up..... Question..... What is everyone doing with the harness that contains numerous wires that crosses the radiator support??
    would love to see pictures!!
    Thanks!!
  4. #14
    Aug 2013
    1994 z28 2005 gxp
    Wentzville, MO
    Thanks!!
    i'm not done with mine yet, but i just past it through to the front of the radiator. i was thinking i would just use some clips to stick it to my uper support.
  5. #15
    Moderator | Founding Member
    Nick
    1994 Camaro Z28
    Lakewood (LA), CA USA
    '1-55241-X' here. All I really did was clearance the upper corners a bit and remove the slanted base on the bottom tray. It just sits flat now. The core support was only cut for the filler/cap and LS lid filter.
    I'm going to run the steam pipe to the upper heater hose outlet on the pump. Not the best picture but you can see the barb fitting here:
    Depending how well that works, I may end up tapping the return side instead. That's arguably the better way since you wont be returning "steam" to the inlet side.
    [ Nick ]
    '94 Z. H/C/I with nearly every bolt on known to the f-body owner.
    [ Album | FQuick ]
  6. #16
    Aug 2013
    1994 z28 2005 gxp
    Wentzville, MO
    very clean
  7. #17
    Oct 2013
    Evansville, IN
    McCauley.... Very clean!! I left my bottom support stock, so my radiator is standing up and tight against the top support with minor modification..... What are your plans for the harness that ran across the support??
    i will definitely copy your steam pipe idea.... Awesome!!!!
    blkchevy..... Do you have any pics??
    as it stands now, it appears there is not enough lenghth in the harness to stretch it front of the radiator in the stand up position..... I would like it out of site to keep it out of the way of my fans, turbo etc.
    just looking for ideals and options
  8. #18
    Nick
    1994 Camaro Z28
    There was barely enough slack to run the harness in front of the radiator IIRC. I had already done the wire tuck on the passenger side so, ideally, I would route the harness through the core support above the radiator. Hadn't played around with it too much though. Since then, I've gone 24x and have a new harness from BP. Beautiful piece but it hasn't been out of the box yet. Not sure how everything will turn out once I get it in.
    [ Nick ]
    [ Album | FQuick ]
  9. #19
    The FABRICATOR!
    Jul 2011
    southern illinois
    Did you ever get those water pump spacers mounted?
  10. #20
    Nick
    1994 Camaro Z28
    Another fantastic product right there! Unfortunately, I haven't installed them yet. Still working on the engine build. I'll be sure to get good pictures with the spacers installed before and after final assembly though.
    [ Nick ]
    [ Album | FQuick ]
  11. The Following 3 Users Say Thank You to McCauleyWB For This Post:
