Results 1 to 10 of 29
10-22-2014, 06:35 AM #1
Stand Up Radiators***** Let's See Them
Griffin radiator should arrive today, so I have my weekend project. I've seen people that retain the upper radiator support, and that's what I would like to do.
would like to see how you modified your bottom support as well as the top.
let's see your pics.....
Thanks!!
Tim96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
10-22-2014, 10:25 AM #2LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
i moved my lower support forward a few inches, then notch the upper mount on mine. I'm trying my hardest to use the stock radiator and fans though.
i later just cut the top off and re built it with square tubing and a flat piece to make it look similar to factory. that was easier than trying to box it back in lol
10-22-2014, 01:10 PM #3
The Following User Says Thank You to NASA For This Post:
10-22-2014, 01:16 PM #4Long Live the Opti
- Sean
- 1999 Twin Turbo Corvette
- Fort Wayne, IN
- 12,072
@NASA I want to see more of your car. I am digging everything I'm seeing.
10-22-2014, 01:46 PM #5LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
wow great setup.
10-22-2014, 04:04 PM #6
Keep them coming...... Would like to see more where the stock upper support is used..... Thanks!!
10-28-2014, 11:24 AM #7LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
lots of pictures here.
http://ls1tech.com/forums/forced-ind...le-here-2.html
i've decided to scrap my idea of using my stock one, my son decided to stand on it... plus i'm still having space issues.
what griffin did you go with? the GRI-1-25241?
also what everyone doing with the two small ports on the the waterpump? are they just welding in bungs or blocking them off?
10-28-2014, 04:27 PM #8
I went with the GRI-55241-X...
not it sure about the ports on the water pump. I'm still using heart core, but ditched the A/C box.... Going to ditch the heater now though as I never drive during the winter. Any idea of what to do with the smaller hose from radiator to water pump??
thanks for sharing the pics..... My radiator came in damaged from Summitt so I have more time to look for ideas.96 Vert 383 forged AFR 210 LT4 Intake CP Pistons T400 Moser 9" Borg Warner S480
10-28-2014, 04:46 PM #9LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
whats the difference from the 55241 and the 25241? looks like they are the same size, thickness, same ports.... ones just cost 100 more lol
10-28-2014, 04:57 PM #10LTX Master
- Aug 2013
- 1994 z28 2005 gxp
- Wentzville, MO
- 897
never mind
Ok to go into this a little deeper here are the three options you can get from Summit
1. GRI-1-25241-x, (This is what everyone gets) 27.5"x15.5"x3", core size is 2" with an overall of 3". This uses only a 1" tubing!
2. GRI-1-55241-x, same dimensions all around including core size but uses a 1-1/4" tubing
3. GRI-1-55241-xs, same dimensions as previous but changes to a 2.5" core and overall is 2.5". Also uses a 1-1/4" tubing
