Results 1 to 10 of 33
Hybrid View
10-19-2014, 04:23 PM #1
8 different codes all of a sudden.
Back ground on my car, last year I did a h/c install, everything went pretty good, it is currently on a mail order tune. I had some oil pressure issues that I fixed, a battery draw, and hard starting when the car has been up to operating temps. Basically it stumbles to life, but always starts. Car has new plugs, wires, gm opti, original coil, and an electric water pump. I am assuming the water pump is causing the draw, but I will sort that out later.
After changing the coolant one last time, the car all of a sudden popped up a check engine light. Scanned it, DTC CODES 42 43 44 45 51 53 54 55.
I checked the car, assuming I left something unplugged, or bumped something, but I can't figure it out. There is no change in drivability, idle, no missing. The car acts exactly the same, except it has the codes. I am currently puttin the car into storage, and will be dealing with the codes next year. I have not hammered it down, as I am waiting to get it on a dyno to make sure all is well.
All ideas welcome. Let me know if you need more info.1994 Trans Am GT, stock 28k mi bottom end LE2 H/C/I , 1.6rr, LT4 KM, moroso cai, jet hot lts, hooker y-pipe, slp powerflo, 37# inj, 255 pump, built 4l60e, 2800 stall, spohn/hotchkis/qa1 suspension etc etc.
10-19-2014, 09:29 PM #2Lurker
- Dec 2011
- Jonathan Englund
- 1994 z28/1994 formula
- Nebraska
- 549
google those codes and see what you come up with.
10-19-2014, 10:04 PM #3LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
I have seen this before. Those are bogus codes. Any group like that containing DTC51 isn't to be trusted. Most likely cause is low battery voltage or bad power/ground wiring to the pcm.
10-20-2014, 09:03 AM #4
That would make sense. This battery (new) I had to bring back to life a couple times because I forgot to unhook it (because of the draw). The voltage looks ok on the dash, but I suppose I should read it with a voltmeter.
For the codes, here they are.
42 - Ignition control circuit, short or grounded
43 - Knock sensor circuit
44 - Bank 1 (left) O2 sensor, lean
45 - Bank 1 (left) O2 sensor, rich
51 - EEPROM program error
53 - System voltage high
54 Fuel pump circuit low voltage
55 - Fuel lean monitor
Some of them don't even make sense, like the o2 being rich AND lean?
Looks like it might be the battery or am electrical gremlin....yay!Last edited by 94ndta; 10-20-2014 at 09:06 AM.
01-20-2015, 07:00 PM #5
I'm going to bump this again. In the spring, I'm bringing my car back to my place and starting working on it again. Now I am pretty sure the draw is related to the electric water pump, as electrically that's the only thing I changed. It works as it should, only comes on when I start the car, but I'm wondering if I did something wrong when wiring it up. What are some other things I can check for the draw? Pretty sure I will need a new battery, too, which sucks as this is another brand new battery down the drain. Thanks.
01-20-2015, 07:59 PM #6Lurker
- Nov 2014
- rob
- 1993 z28
- West side of chi- town
- 430
Does it have an aftermarket alarm?
BUILD THREAD PROJECT "BAIL MONEY"93 Z28 STOCK BOTTOM END/HEADS, MSD COIL, MSD 6AL, MSD 8972 RETARD, L.E. CAM 227/235 565/579 110 LSA, COMP 1.6 RR, PCM OF NC TUNE, PACESETTER LTS, !CATS/EMISSIONS, ORY, DUMPED BULLET, EDGE 3600 STALL, 3:23 10 BOLT, LCAS, RELO BRACKETS, PHB, 125 SHOT - (ALMOST READY TO SPRAY....)
01-20-2015, 08:03 PM #7Lurker
- Nov 2014
- rob
- 1993 z28
- 430
or aftermarket stereo and/or amplifier?
01-20-2015, 08:04 PM #8
01-20-2015, 09:41 PM #9LTX Regular
- Aug 2013
- Gary
- 1998 Trans Am
- Florida
- 241
Here is one way to go: Buy a digital clamp meter to measure the battery drain while you pull fuses.
http://www.ebay.com/itm/New-MASTECH-...1cc&rmvSB=true
01-21-2015, 10:00 AM #101994 Trans Am GT, stock 28k mi bottom end LE2 H/C/I , 1.6rr, LT4 KM, moroso cai, jet hot lts, hooker y-pipe, slp powerflo, 37# inj, 255 pump, built 4l60e, 2800 stall, spohn/hotchkis/qa1 suspension etc etc.
