Results 1 to 10 of 12
08-20-2014, 09:46 AM #1LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Recommended fluid type for GM transmissions
I get asked quite frequently about what transmission fluid we recommend for the GM transmissions we build. The answer used to be a little more simple... Dexron III / Mercon. However, GM no longer allows oil companies to use the word "Dexron". Most companies have switched to calling it "multi-vehicle" fluid. Oue experience has been that we've seen no benefits from using synthetic fluid in a 4L60E, 400, 350, 700, 4L80E, 2004R, etc. Now, if you use a particular synthetic and you're happy with it, then there's nothing wrong with it. It's just that you're spending more money than you need to. As far as brands go? Most fluid comes from the same place and put in bottles with different names. Parts store brand fluid will work just as well as brand name fluid. The only thing we tell everyone not to use is really cheap fluid or recycled fluid. Cheap fluid is usually easy to identify because it has no dye in it to give it the pink/red color.
NEVER, under any circumstances put any additives in your automatic transmission! Most additives are nothing more than repackaged brake fluid. Stuff like Lucas will break down the rubber seal and turn them into a gelatin type substance. Once that happens, they will disintegrate. Lucase swells the rubber seal. This is how it "stops leaks". When we take a trans apart that has had lucas in it, we have lip seals on the pistons that are gooey and hanging off the pistons. The seal is supposed to fit tightly into the groove in the piston, but after Lucas, you will have a piston with a 6" diameter, but a lip seal with a 7" diameter.Gail C. Cahall
The Following User Says Thank You to CPT For This Post:
08-20-2014, 10:26 AM #210 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
Sticky? @popo8
-Josh
co-owner of BDBRacing.com
NMCA OC 9004
08-20-2014, 11:19 AM #3InActive Member
- Jun 2014
- Dan Jaeger
- 1993 Camaro Z28
- Terre Haute, IN
- 47
Any suggestions for my 93 m29/t56?
Using Tapatalk
08-20-2014, 11:29 AM #4LTXTech Sponsor
- Jan 2013
- Gail C. Cahall
- Newark, Delaware
- 619
Sorry, Dan. I only build automatics. I'm not sure what to use in a stick.
Gail C. Cahall
08-20-2014, 11:43 AM #5The FABRICATOR!
- Jul 2011
- Chris
- 1985 Monte Carlo SS
- southern illinois
- 7,164
08-20-2014, 11:46 AM #6InActive Member
- Jun 2014
- Dan Jaeger
- 1993 Camaro Z28
- Terre Haute, IN
- 47
Alrighty, just figured I'd ask, she needs a flush and a new rear seal. Appreciate the info and the response anyway.
Using Tapatalk
08-20-2014, 02:00 PM #7
The side of my 1995 t56 says dex II, yes as in 2. Not a typo. At the GM dealer I work at we put dex 6 in em.
08-20-2014, 09:09 PM #810 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
I've used store brand Dex 3, until now (10 years of race seasons) without any issues. Switched to Redline shockproof light weight gear oil this season but that's for the faceplated gears.
-Josh
NMCA OC 9004
08-21-2014, 01:53 AM #9"The Rock"
08-21-2014, 03:19 PM #10InActive Member
- Oct 2008
- greg
- 1995 z28
- central iowa
- 100
hey frank what if the synthetic is mostly clear/tannish color?
1995 Z28 mostly stock 3.73 gears shift kit 3"exhaust subframe connectors soon to have a newish topend
