Results 11 to 20 of 50
Thread: Lightweight Battery Test
07-15-2014, 06:10 PM #11Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- Elizabethtown, Kentucky
- 3,033
I dont mess with the radio or even have it on If the car aint running. Thinl I may just have to get one of these
Kyle
07-15-2014, 06:11 PM #12Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- 3,033
For anyone wanting to get one from advance go on line and at check out use promo code p20. U save 20% up to $50
Kyle
07-15-2014, 06:19 PM #13
Once the car is running, the alternator is providing the juice. The battery dictates your cranking and cold cranking amps (how long you can turn the starter). It will also affect how long the car can sit without running, without the battery dying on you. Those would be the things to test.
07-15-2014, 11:15 PM #14
I just put my optima in the spare tire area. butvdef a good idea. I always wondered, just never tried it
07-16-2014, 05:23 AM #1510 Second N/A Club
- Josh
- 96 Z28
- Holden, MO (KC)
- 2,867
I'm also interested to see how this works out for you. I bought a Dyna Battery to put back up front of my car this year. It's advertised as 13.5lbs but is actually about 14.5lbs. I've got it mounted and it's gonna save me a good 45lbs over the lead acid battery in the back plus all the cable running the length of the car. I haven't gotten mine running yet.
-Josh
co-owner of BDBRacing.com
NMCA OC 9004
07-16-2014, 08:17 AM #16
Here is a better one that I used. http://shop.advanceautoparts.com/o/4...tm_content=bat
07-16-2014, 08:19 AM #171995 TA: Converted Nose...381 LT1...4L80E...Moser 12 bolt...Edge TC...
07-16-2014, 08:35 AM #18Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- 3,033
just ordered one and goin to pick it up after work! what battery wire connectors did u use?
Kyle
07-16-2014, 10:59 AM #19
I laid the battery on its side so you can get more contact area with the top portion as opposed to side mount, pulled the factory bolts out, and used the supplied bolts with the factory cables. I had to get a couple of copper washers to cover the connectors because the bolts will go right through. You'll see what I mean when you try to bolt them up. If you need closer pictures let me know.
The Following User Says Thank You to Mystery Bird For This Post:
07-16-2014, 02:05 PM #20Lurker
- Aug 2009
- Kyle
- '95 Trans Am
- 3,033
wonder how long one will last in a weekend warrior car?
Kyle
