Page 2 of 9 FirstFirst 123456 ... LastLast
Results 11 to 20 of 84
  1. #11
    Oct 2009
    El Paso, TX
    That may be my problem because he converted it to R134A
  2. #12
    Oct 2009
    El Paso, TX
    I did some research on R134A conversion for C4's and it looks like my mechanic did it right, so that leads me to believe that the problem does not lie with the conversion.
  3. #13
    You can also by a metal heat shield to protect the starter. Its got insulation between two layers of metal.
    http://www.jegs.com/i/Moroso/710/743...FSsV7AodxHMADw
    And as much as I hate wrapping headers, consider wrapping the section right next to the starter.
  4. The Following User Says Thank You to Injuneer For This Post:
  5. #14
    Oct 2009
    El Paso, TX
    Thank you for the link and the tip Injuneer.
  6. #15
    Dec 2012
    Tommy N.
    Silver 1996 Camaro Z28, Green 1996 Camaro Z28
    El Paso, TX
    You could also do a ford starter solenoid trick my dad did it on his Camaro
    Silver 96 Z28 SideSwype-DD
    Green 96 Z28 NightMare-Drag car
  7. The Following User Says Thank You to 96z28SideSwype For This Post:
  8. #16
    Oct 2009
    El Paso, TX
    Thanks sideswipe. That's the plan if the mini starter doesn't solve the problem. My AC is working again, it turned out to be an electrical issue.
  9. #17
    Good news on the ac.
    LTXtech.com is my Drug...
  10. The Following User Says Thank You to popo8 For This Post:
  11. #18
    Oct 2009
    El Paso, TX
    Look what showed up today. I'll be installing it this Friday.
  12. #19
    Thats a nice lookin piece.
  13. #20
    Oct 2009
    El Paso, TX
    Thanks popo. It looks to be very good quality.
  14. The Following User Says Thank You to F.G. For This Post:
