Results 1 to 10 of 15
Thread: weight reduction list
01-07-2009, 06:59 PM #1
Borrowed some of this info from other places. Feel free to add to the list we can get a sticky of it up later on.
12..ABS module
15..AC compressor
8.6.AC condenser
21..AC fan motor (entire assembly)
14..Airbag and bracket, passenger's
4...Airbag, driver's
.....Air dam
1...Air filter
6...Air Pump (w/brass fittings)
3...Amp, Monsoon
4...Antenna, bracket, and motor if applicable
1...Ashtray & lighter
.....Blinker switch
2...Bolt lengths, extra
.....Brake pedal pad
22..Bumper, front reinforcement and brackets
21..Bumper, rear reinforcement and brackets
41..Carpet & Sound deadening
50..Catback
15..Cats
10..Center console
.....Coating, under carpet
5...Coolant Overflow
4...Crossmember brace
5...Cruise control (w/cable, throttle cable cover)
11..Dash
6...Dash brace (steel)
5...Dash Pad
4...Dash Replacement
18..Door panel (TA, both)
1...Door panel insulation
15..EGR, air pump, & harware
.....Emblems
.....Fan
.....Fan shroud
5...Fenders (Inner metal)
7...Firewall Insulation
13..Firewall Insulation w/ plastic
5...Floormats
3...Foglights and brackets
.....FRA mod
7...Gas, Extra (per pound)
23..Gas Tank (steel)
20..Gas Tank (plastic)
5...Gas Tank Evac Box
2.5.Glovebox
1...Grill insert
4...Hatch cover
2...Hatch shocks
20..Headlights/metal frames
2...Headliner
4.4.Head unit (Monsoon)
.....Head unit/AC console trim piece
8...Heat sheilding
9...Heater core (w/water)
42..Hood (LT1)
8...Hood Latch w/ brackets
1...Hood shocks
3...Horn
3...Inner fenderwells, plastic
2...Intake Silencer
.....License plate brackets
2...License plate(s)
1...Lug Nuts (Chrome)
1...MAF
13e.Manifolds (stock)
.....Misc. junk in the car like keys, garage remote, change, etc.
4...Overflow Tank
1...Owner's manual
3...Panels, under steering wheel
17..Panhard rod (TRZ kit)
5...Panhard rod brace, upper
.....Parking brake
.....Power brake booster
5...Parking brake handle
.....Power seat motor
12..Power steering pump, pulley, idler pulley
.....Power window motors
17...Radio (stock in center panel)
1...Rear view mirror
9...Seatbelts (rears and passenger's)
35..Seat, driver's (cloth)
45..Seat, front (leather)
30..Seat, passenger's (cloth)
32..Seat, passenger (leather)
28..Seats, rear (leather)
3...Sheetmetal, extra double walled
1...Shifter knob
20..Side impact bars (doors)
37..Spare tire and jack
6...Speaker panels, hatch
5...Speaker panels, rear passenger's
15..Speakers
5...Speakers (mid-base Monsoon, pair)
5...Speakers (Alpine, pair)
18..Spoiler (Weight measured on a Pontiac)
.....Spring isolators
2...Sun visors
14..Swaybar and brackets, front
1...Swaybar metal attachment
.....Taillight(s)
12..T-Tops
2...T-Top holders
11..T-Top hump/sheet metal
3...TCS motor
.....Under car tow points
1...Washer fluid pump
8...Windshield washer fluid
3...Windshield wiper reservoir
4...Wiper arms
10..Wipers/motor
.....Wiring, Excess
21..Y-Pipe (w/1 cat.)
2...Y-Pipe hanger (stock, connected to tailshaft)
93 Trans Am - TCGiRL220's Dad
I'm the one who gets all the fun jobs
01-07-2009, 07:00 PM #2
sweet thanks! i'm starting my weight reduction this sunday, really apperciate this..
looks like i'll shed about 278 lbs! sweet that should offset the rollbar just fine..Last edited by grn95t/a; 01-07-2009 at 07:07 PM.
Chris Close
01-07-2009, 07:00 PM #3LTX Member
- 1997 Camaro SS
- Overland Park, Kansas
- 5,172
You might look up information about wheel weights... Stock 16x8's vs prostars vs 17x11 ZR1s, etc.
-Eric
01-07-2009, 07:04 PM #4Post Whore Moderator
- Westchestertonfieldville, IA
- 3,960
Thank you for the good info. Looks like I'll only be able to shed a couple pounds though. Keeping it as streetable as possible!
~Shane
94 Z M6 304hp/336tq
12.61 @ 109.7
01-07-2009, 07:06 PM #5LTX Member
- 1997 Camaro SS
- 5,172
01-07-2009, 07:30 PM #6
If anyone else has any more weight mods that you have found please add and put the weight for it
We are currently in the process of alot of weight reduction and we will add more information as we go along...
Power window motor is 3 lbs.
Tawny aka Daddy's Girl
Never drive faster than your guardian angel can fly
01-07-2009, 08:26 PM #7LTX Member
- 1997 Camaro SS
- 5,172
here's some more good info
http://www.bfranker.badz28.com/fbody/weights.htm
-Eric
01-07-2009, 10:36 PM #8LTX Regular
- Oct 2008
- 1994 LT1 Camaro
- Port Charlotte, Florida
- 479
Great info!
94 Camaro: 10.57@127, AI H/C, stock bottom, 150 n20, TH400, 8.8 rear (11.49@119 n/a T56)
99 Z28 1SC Stripper: 5.3, S480, Th400, MWC 9"
01-19-2009, 10:27 PM #9
found this on another site i visit
Camaro & Firebird F-body Weight
Engine Compartment
460.9 lbs - LT1 (5.7L) Manual with oil and flywheel
428.8 lbs - L36 (3.8L) Manual with oil and flywheel
405.5 lbs - LT1 (5.7L) Auto with oil and flexplate
391.2 lbs - L36 (3.8L) Auto with oil and flexplate
40 lbs - Optima red-top battery (sounds heavy???)
32 lbs - Madman manual rack & PA chromemoly k-member
25 lbs - Pair of stock manifolds with AIR tubes off LT1
18 lbs - AC compressor with lines
18 lbs - ATI 3 core F-Body intercooler
17 lbs - AC compressor with lines
14 lbs - Dyna Battery
12 lbs - Plastic insulation on firewall
12 lbs - ATI 2 core F-Body intercooler
11 lbs - Full windshield washer reservoir
10 lbs - ABS unit
9 lbs - AC condensor
9 lbs - AC condensor with accumulator
8-9 lbs - OEM motor mounts (pair)
8 lbs - Bracket for PS/AC compressor
7 lbs - Competition Engineer solid motor mounts
7 lbs - AIR pump hoses and bracket
4.4 lbs - Cruise control
3 lbs - EGR valve and aluminum tube
3 lbs - Wiper motor
3 lbs - BMR 2 point strut tower brace
3 lbs - All exhaust heat shields
2 lbs - Factory oil cooler lines
1.5 lbs - Horns (pair)
1lbs - Heater core lines
Drive Train
190 lbs - Moser 9″ (3.250 bearing) w/35 spline axles, Strange nodular iron section, full spool, 3:70 gears, no oil
135 lbs - Stock 7.5 rear end w/3.73 gears and oil
40 lbs - Centerforce heavy flywheel
35 lbs - Vigilante torque coverter new in box (inc box!)
34 lbs - Steel 2pc V6 driveshaft including center bearing carrier
28 lbs - A TH400 with 9″ converter is 28 lbs lighter than the 4L60E
20.5 lbs - LT1 stock flywheel
20 lbs - LT1 stock flywheel
16 lbs - Stock steel LT1 driveshaft
12.5 lbs - TPiS lightweight flywheel
12.2 lbs - 3rd gen aluminum 1LE driveshaft
12 lbs - LPE aluminum driveshaft
11.5 lbs - Stock aluminum LS1 driveshaft
10 lbs - RK Sport aluminum 1pc driveshaft
10 lbs - ??? brand lightweight flywheel
4 lbs - Transmission tunnel insulation
Wheels & Tires
58 lbs - AFS chrome 1711 GS offset wheel with new Dunlop SP8000 315/35/17 tire
56 lbs - AFS chrome 1711 GS offset wheel with BALD Dunlop SP8000 315/35/17 tire
56 lbs - 189 chrome Cobra R replica wheels with 285/35/18 tires
55 lbs - AFS silver 1711 GS offset ZR1 wheel with new tire
55 lbs - 17″ Prime chrome 5 Stars with 275/40 tire
55 lbs - 17″ chrome Firewhawk wheel with new tire
54.5 lbs - Replica SS wheel with Khumo 712 275/40 tire
52 lbs - AFS chrome 179.5 ZR1 wheel with new Dunlop SP8000 275/40/17 tire
50 lbs - OZ Monte Carlo 179.5 with 1/3 tread 275 GSC
50 lbs - AFS polished 1711 GS offset ZR1 wheel with new 315 BFG Comp TA drag radial
48 lbs - 168 stock chrome 5 star with Kuhma Estca Supra 712 tires (V rated)
45 lbs - 99 TA stock 16″ chrome wheels and tire (SZ 50)
44 lbs - 93-96 Camaro wheel with Nitto drag
41.5 lbs - 93-96 Camaro wheel with bald 255 BFG drag radial
40 lbs - Weld Pro Star (1510) with new Hoosier QTP 2811.5-15 (no tube)
35.3 lbs - New Dunlop SP8000 315/35/17 tire
31 lbs - New Dunlop SP8000 315/35/17 tire - hmm?
31 lbs - Kumho Victoracers 275/40/17 tire
30 lbs - New Dunlop SP8000 275/40/17 tire
29 lbs - 97 to 99 Vette standard rear wheel
28 lbs - Kumho Victoracers 315/35/17 tire
27 lbs - Weld Pro Stars (153.5) with Cooper 165R tire
27 lbs - 189 chrome Cobra R replica wheel
25.5 lbs - Hoosier A3S03 Autocross tire 315/35-17
25 lbs - Firestone SZ50EP stock size tire
25 lbs - New Futura 275/40/17 tire
24.5 lbs - Goodyear GSC 245/50/16 tire
24 lbs - 97 to 99 Vette magnesium rear wheel
22.5 lbs - Hoosier A3S03 Autocross tire 275/40-17
22 lbs - 90 Vette stock wheel 179.5
22 lbs - Hoosier R3S03 275/45/16 tire
22 lbs - 01 Camaro SS 179 wheel
22 lbs - 2 piece Centerline Sabre type 179.5 wheel
21.5 lbs - 97 to 99 Vette 189.5 wheel
20.06 lbs - 00 Vette standard rear wheel
20.5 lbs - OE ZR1 179.5 wheel
20.5 lbs - AFS replica 16″ SS wheel
20.1lbs - 97 to 99 Vette magnesium front wheel
20 lbs - CCW 1710 wheel
20 lbs - CCW 1711 wheel
20 lbs - 3 piece Centerline Sabre 179.5 wheel
19.5 lbs - 1996 stock Camaro wheel
19.5 lbs - Stock 5 star 16″ Z28 wheel
19 lbs - 2000 stock Camaro wheel
19 lbs - 97 to 99 Vette 178.5 wheel
18-19 lbs - Centerline 179.5 wheel
18.08 lbs - 00 Vette standard front wheel
18 lbs - Fiske FM5 179.5 wheel
17 lbs - 2000+ stock Camaro wheel (different than above?)
13 lbs - Weld Pro Star (158)
10 lbs - Weld Pro Star (153.5)
10 lbs - Bogart DragStar 1510 racing wheel
Interior
65 lbs - Wolfe weld-in 6pt. roll bar
42 lbs - 1997 Camaro front leather power seat
40 lbs - Carpet with the sound deadener
38 lbs - Spare tire and jack
36 lbs - Spare tire and jack
34 lbs - Passenger seat
32 lbs - 1997 Camaro front leather manual seat
29 lbs - Rear seats
24 lbs - Heater core
20 lbs - Front & rear seatbelts with bolts
17 lbs - Passenger airbag with bracket
10 lbs - Driver side airbag
9 lbs - Center console (Trans Am)
7 lbs - Under dash AC plastic moulding
7 lbs - Bose speakers (95 Z28)
6.9 lbs - 6 way power seats over manual seats
5 lbs - Stereo
5 lbs - Rear pair of seat belts and retractors
4 lbs - Rear panel with speaker
4 lbs - Rear hatch cover / divider
2.7 lbs - Power windows over manual windows
2.7 lbs - Sunvisor (pair)
2 lbs - Sunvisor (pair)
2 lbs - Glove Box
2 lbs - Rear hatch cover
2 lbs - Insulation glued to dash
2 lbs - Factory Monsoon amp
1.8 lbs - Power door locks over manual locks
1.8 lbs - Rear floor mats
1.3 lbs - Remote truck release motor
1 lbs - Rearview mirror
0.4 lbs - Keyless entry option over no keyless entry
0.4 lbs - Rear window defogger
Exterior
44 lbs - 93-97 Stock Camaro hood with insulation
31 lbs - Rear bumper reinforcement and brackets
23 lbs - Front bumper reinforcement and brackets
12.3 lbs - T-tops
4 lbs - Front impact absorber
3 lbs - Wipers
2.7 lbs - Z28 fog lamps
1.8 lbs - Body side mouldings
Suspension
33 lbs - Suspension Techniques 35mm front sway bar
14 lbs - Front sway bar and brackets
14 lbs - 2002 stock torque arm
13 lbs - Stock rear springs
13 lbs - Front sway bar
12 lbs - Edelbrock torque arm
8 lbs - Rear sway bar with end links
2 lbs - Rear spring perches
2 lbs - Front sway bar mount97 black m6 ss, stainless works o/r y-pipe, 2otl slp muffler, tb bypass, k&n filter in the ram-air, tri-fecta tune, , 97 z-71 silverado, dynomax turbo, vara-ram throttle body insert, k&n filter in factory air box, 2010 kia soul, k&n , 94 mighty max dailydriver
01-19-2009, 10:30 PM #1097 black m6 ss, stainless works o/r y-pipe, 2otl slp muffler, tb bypass, k&n filter in the ram-air, tri-fecta tune, , 97 z-71 silverado, dynomax turbo, vara-ram throttle body insert, k&n filter in factory air box, 2010 kia soul, k&n , 94 mighty max dailydriver
