Results 1 to 6 of 6
    Mar 2014
    john
    93 z28
    decherd,tn
    Default ac problems someone help!!
    so i decided to check why my ac wasnt working first i found the clutch pigtail was cut, repaired it jumped the low switch and charged it up. now this is where i am lost, as the compressor cycles it pulls the pressure down on the low side to the point it cuts off, also while running going down the road you can really feel it cycling like crazy on off on off but while sitting still it cools perfectly but once you give it gas it cycles on off on off. anyone got a clue where to start checking things at i am lost!
    Feb 2014
    95albinobird
    95 firehawk tribute
    mooresville nc
    93 that was around when they were changing from r12 to r134a.is you car r12?
    Mar 2014
    john
    93 z28
    decherd,tn
    No its r134
    Sent from my LG-L38C using Tapatalk 2
    Mar 2014
    john
    93 z28
    decherd,tn
    Its r134
    Aug 2013
    Gary
    1998 Trans Am
    Florida
    Maybe you overcharged it. Have someone put a gauge on it.
    Feb 2014
    95albinobird
    95 firehawk tribute
    mooresville nc
    there is a blow off on the compressor if it's over charged it should release the overage.you may have a bad expansion block that what regulates the pressures.
    i got a compressor kit from rockauto it had o rings the expan block compressor and receiver dryer hell the compressor even had the pag oil in it.
