Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
  1. #21
    Aug 2009
    Cockeysville, MD
    Excellent writeup. Easy to tell it was done by a true "professional".
    For people that go to NHRA tracks, using a hubcentric spacer is required, and your lug nuts must engage the stud threads in an amount equal to the diameter of the stud. In other words, if you are using a 12mm stud, you have to have a minimum of a 12mm length of the threads in the hex portion of the lug nut.
    Just for reference, this is what the brakes look like on the CTS-V... belongs to a buddy of mine:
    Ignore photo.... this is apparently a 2nd-Gen CTS-V with 6-piston calipers.
    This is a very good piece of information. While I didn't measure the thread engagement, I would guesstimate it to be about 10mm. While it is probably enough to be safe; I don't feel comfortable driving it too much.
    Quote Originally Posted by FormulaJoe View Post
    I think that V has the 6 piston calipers by the looks of them, but it's hard to tell. Sweet write up... Definitely looks like quite a bit of grinding was done. Almost looks like you had to do more then what was done in the ls1tech thread with the 17" ZR1s?
    I compared pictures and he took a lot less off than I had to. The wheels I'm using are cheap Chinese wheels. I love the look of the wheels, but they really don't compare dimensionally to most higher quality wheels. My situation is very unique as most F-body guys will run Vette replica's or a higher end wheel than I do.
    Quote Originally Posted by casey20000007 View Post
    Where can I get a set of 6 piston calipers
    Keep in mind that the 6 piston caliper CTSV 's use a 15" rotor and require at least a 19" wheel if you are using them on a F-body. I'm unsure of what rotors you would use for that particular setup.
    Quote Originally Posted by CamaroZGuy View Post
    i wonder if the OEwheels C5 dished 18s would fit with out grinding, 18x9.5 54mm offset
    If you have a straight edge and a tape measure, lay the straight edge across the mounting flange of the wheel, and use that to measure outward to the spokes. One of my pictures have the measurement from the hub to the caliper. If your measurement is larger than mine, they will fit. If not, you may need a spacer.
  2. #22
    Quote Originally Posted by Tbird232ci View Post
    not totally ture, im running 18' wheels with the 6 piston v calipers and a zl1 14.8 rotor, fits tight but it fits and there is no pad over hang
  3. The Following 2 Users Say Thank You to 94m6z28 For This Post:
  4. #23
    Jan 2012
    1997 z28 383 stroker
    oklahoma city,ok
    Quote Originally Posted by 94m6z28 View Post
    That's very nice
    Smoke tires not drugs
  5. #24
    Overworked/Underpaid
    Aug 2012
    Peter Alpiger
    1996 Trans Am WS6; 1994 Corvette [GS Clone]
    Carrollton, Texas
    Fapfapfapfap
    Just another all show no go bird
  6. #25
    Jan 2012
    oklahoma city,ok
    Default CTSV front brakes.
    @94m6z28 how much did that set up cost? Not the wheel
  7. #26
    i cant tell if that "Fapfapfapfap
    Just another all show no go bird" is your tag thing or a comment on my car? @Blackbird96WS6
    @casey20000007 if i recall , the rotors were 350 ish plus some work to get the center bore to fit the ls1 spindle, calipers were 280-300, gm pad kit was 180, pin kit was 20 bucks, then brake lines and a few odds and ends, all OE gm parts
  8. #27
    Jan 2012
    oklahoma city,ok
    The fapfapfapfapfap is the comment on the brakes and the all show no go bird is his sig
  9. The Following User Says Thank You to casey20000007 For This Post:
  10. #28
    Aug 2012
    Peter Alpiger
    Carrollton, Texas
    Yeah sorry, the Fapfapfapfap is for the brakes lol. The rest is my sig line in Tapatalk. Love the way it looks man!
  11. #29
    ah gotcha haha not on here enough to get how all this stuff works:P thanks man, its takin a lot of time to pick everything
  12. #30
    Jan 2012
    oklahoma city,ok
    What Did it cost for brakes and rotors
