Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 42
  1. #11
    Dec 2011
    1994 Firebird Formula. Manual.
    Too close to the cities, MN
    I think that V has the 6 piston calipers by the looks of them, but it's hard to tell. Sweet write up... Definitely looks like quite a bit of grinding was done. Almost looks like you had to do more then what was done in the ls1tech thread with the 17" ZR1s?
  2. #12
    Big Papi
    2015 Fusion Titanium AWD
    Moscow Mills Mo
    Blog Entries
    1
    First gen v's have 4 piston seconds have 6
  3. The Following User Says Thank You to Chris For This Post:
  4. #13
    Quote Originally Posted by Chris View Post
    Good call. I blew up the original of the photo, and there are three "bumps" on the caliper where there are only 2 on the conversion calipers. I'll delete the photo.
  5. #14
    Jan 2012
    1997 z28 383 stroker
    oklahoma city,ok
    Where can I get a set of 6 piston calipers
    Smoke tires not drugs
  6. #15
    Quote Originally Posted by casey20000007 View Post
    ebay...
    LTXtech.com is my DRUG!
  7. #16
    Jan 2012
    oklahoma city,ok
    I thought someone might now of another place
  8. #17
    GM dealer
  9. #18
    "Project Storm Trooper"
    Tony
    93 StormTrooper Z28
    Rapid City, SD
    i wonder if the OEwheels C5 dished 18s would fit with out grinding, 18x9.5 54mm offset
    Official Member of $30k Club ​- Work in progress
    1993 Z28- 24x EFI, Clayton Racing 383ci, F1a w/FMIC, AFR 210's, LE Custom cam, LE LT4 Intake/heads, 80# injectors, 255lph/340lph pumps, T56 Conversion, 9" 4.11 w/spool, LPP LT w/Borla, Full UMI suspension....
    1987 Iroc-Z - Stock Summer DD
  10. #19
    Big Papi
    Moscow Mills Mo
    Blog Entries
    1
    Amazon
  11. #20
    Big Papi
    Moscow Mills Mo
    Blog Entries
    1
    Default CTSV front brakes.
    Well amazon used to have the silver ones in stock at 200 each iirc must be sold out a lot of ppl are using them
    http://www.amazon.com/gp/aw/d/B00559...&robot_redir=1
    http://www.amazon.com/gp/aw/d/B00559..._SS115&simLd=1
